Feb 21, 2005, 03:34 PM
Question
how to build in an endgrain/carbon spar
I've had success with building smaller wings. I'm into a 120 in plane now and I'm not sure the best way to get the end grain spars installed. building the spar under vac with angle iron seems easy enough.
Know of a link to a build that details this part.
Also not so sure on the best way to install the joiner-I'm going with 1/2in steel rod in 1/2in ID cabon tube.
The plane that I'm working on can be found here:
http://www.rc-soar.com/tech/craig.htm
Feb 21, 2005, 04:47 PM
Build & Fly
How's this?
http://www.cstsales.com/HTBuildCarbonSpar.htm
The carbon braid they use isn't cheap but it is very strong. A more budget friendly option is to wrap the carbon capped balsa assembly with kevlar thread. It takes to the corners better and is more than strong enough. The kevlar wrap method is used in several Drela designs and no one has ever complained about failures - just about the tedious wrapping part. Go here and browse the plans and photos sections for the kevlar wrap details on several different planes.
http://groups.yahoo.com/group/allegro-lite/
Feb 21, 2005, 04:58 PM
F3X
F3X
F3X's Avatar
http://www.favonius.com/soaring/bagging/bagging.htm
Great project, see if the above link helps some.
How to build an F5B Wing....the video... (In composites section) soholingo High Performance 17 Jul 11, 2015 12:16 AM
Mini-HowTo Make a Spektrum RX range check in an all-carbon fuselage Andrew McGregor Sailplane Talk 250 Jul 03, 2013 11:32 AM
Build Log Jaro Muller Mini Elipse,The Build in an evening Jantar2A Slope 4 Mar 06, 2007 06:49 PM
Help! How the hell do you line up an endgrain spar?? I'm Rick James Slope 15 Nov 15, 2006 12:00 AM
Article How To Break-In an 05 Can Motor Terry Gamble Power Systems 0 Apr 01, 1996 01:00 AM
