Sep 05, 2019, 04:39 AM
Tony Audsley Retired Locksmith
Lockey's Avatar
Finished and ready to fly again
Lockey
Sep 05, 2019, 07:43 AM
Foamy and Glider fanatic
Blacky's Boy's Avatar
Wow, she's a beauty! Nice job on the coating, finish and details!
Sep 05, 2019, 07:53 AM
Lockey's Avatar
Thanks BB, Just got a vinyl cutting machine so had to try it out
Lockley
Sep 05, 2019, 01:21 PM
I can see where that would be REAL useful!!
Before I got back into RC I used to work for a manufacturer of safety covers. They had a nice production floor filled with machines. But my favorite was the 40 ft long x 10 ft wide CNC fabric cutting machine that could cut foam, vinyl, PVC up to 1/32" thk. If it was dense enough, the vacuum table could hold it down. And if it wasn't, you used a sheet of thin paper on top of your work piece to "clamp" it in place while it cut.
I could have used that for cutting out foamie parts or wing formers out of balsa.
And to add insult to injury, they had an industrial sized vacuum former and a stack of scrap I could use when I wanted. I could have made replacement canopies or cowls. The list goes on.
I sometimes lament leaving the place.
Then I remember the reasons I left,................and then I don't feel so bad.
Sep 05, 2019, 09:10 PM
Lockey's Avatar
Because I hated the cutting out of the foam parts, (love building but hated cutting out the parts .. AND .. the edges were never square slots too loose or too tight etc) so I made myself a CNC router
Started with a Anycubic Mega and advanced to a prusa i3 mk3 ... love the idea of 3D printing the fuselage BUT at this stage it is maybe a bit heavy and brittle but still like it and am doing some of the parts
Rolled wings are fun to make but a bit time consuming (and hey .. at my age, I dont have lots of that left ) so I have decided to make a hot wire CNC cutter to do this just waiting for a few more of the parts to arrive before I start building
A vinyl cutter is a nice addition for doing the fancy bits, decals and the like and at this price (remember this is AU$ .. about US$ 238) who wouldn't buy one https://www.amazon.com.au/dp/B075L5R...292_TE_3p_dp_1
AND .. a simple vacuum former would be a nice addition
I am also looking at getting a better PC dedicated to do CAD work as mine is a little slow and occasionally, siezes up on me, or worse ... blue screen
Ahh .. retirement .. what else can I make ... buy .. ? .. not sure what they will do with all this sh!7 when I pass on to the model room in the sky
Lockey
PS... sorry about the deviation from the thread .. just waffling .. and waiting for Bob to chirp in
Sep 05, 2019, 10:01 PM
Retired CAD guy
birdofplay's Avatar
I chirped in on your g-mail ;>}
Sorry , I havent had time to do much as I got a bunch of orders out today.
Re vinyl cutter:
I HAVE enough "stuff" to build a 5W Laser diode engraving machine.
Got the aluminum frame stuff and Controller board, belts wheels n stuff.
I wonder if I could make it so I could toss on a Swivel knife and use it to cut vinyl also ?
Other wanderings:
I ALSO upgraded my Network recently and I'm up to 15g ( so they say) now !
It is faster and my pads work better and my other net gears are working glitch free now too !
I never would have guessed that net speed would make those kind of glitchy things go away !
Sep 05, 2019, 10:03 PM
Lockey's Avatar
Originally Posted by birdofplay
I chirped in on g-mail ;>}
Sorry ,I havent had time to do much as I got a bunch of orders out toady.
OOOOOHHHHH a laser engraver .. YES .. YES
Lockey
Sep 15, 2019, 04:55 AM
Lockey's Avatar
Flew the Venum again today, flying really nice now .. I upped the aileron throws a bit but it wouldn't hurt to up it even a little more
I think the undercarriage needs to be a bit stronger
Lockey
Venum x Flying nice (2 min 59 sec)
Sep 15, 2019, 07:47 AM
When cows fly!
Turned out nice! Great flight!
Sep 15, 2019, 04:27 PM
Retired CAD guy
birdofplay's Avatar
Just returned from a long weekend away Fri-Sun PM,
I believe you have nice flying Acro Trainer there !.
Looking terrific too ;^}
You're' really getting on with the Rolls and loops !
Don't be too afraid to get close to the ground before the stall landing.
That LOW WING should provide some Ground effect cushion.
Or move those wheels a little further forward.
Sep 15, 2019, 07:56 PM
treefinder
springer's Avatar
Bob, at the risk of hacking Tony's thread, regarding vinyl cutting, check out my wafer thread in CAD/CAM where I discovered that I can cut nice N numbers and logos with my 2.5 watt laser on my cnc machine built for the needler foam cutter: https://www.rcgroups.com/forums/show...sketchup-users
The best part of it is that I can use the 3d text tool in Sketchup to create the text in any truetype font (hundreds of free downloads online) and make it 5mm high, then run wafer and get the gcode. I then edit the .NC file to change Z commands to laser commands and go. (the commands are already in the correct locations in file, just paste the new ones over the old ones.)
Sep 15, 2019, 08:10 PM
Lockey's Avatar
Nice model Mike
Lockey
Sep 15, 2019, 08:55 PM
Lockey's Avatar
Bob, here is a better landing (though still a bit heavy on the landing gear )
This was the very short flight I did before the other one and found that I had a duff battery and I had forgotten to do something about upping the aileron throws so brought it in straight away
The landing gear is 3mm stainless steel wire and is quite a bit softer than the piano wire .. might have to make a new undercarriage for it or go for a CF landing gear .. unfortunately, 3D printed ones tend to be too brittle and break too easily .. especially with my heavy landings
Lockey
Venom x short flight before upping the throws on ailerons (1 min 31 sec)
Sep 15, 2019, 09:25 PM
When cows fly!
Wow! Nice little flight
Sep 16, 2019, 07:28 AM
Retired CAD guy
birdofplay's Avatar
Ditto !
Discussion Venom x-28! derk Micro Ready-to-Fly 62 Aug 28, 2009 10:23 AM
New Product NEW: Venom X-Wing X28 Flyer thrashaero Micro Ready-to-Fly 31 Aug 20, 2009 11:49 AM
Discussion Venom X-28... anybody tried it? Akura2 Micro Ready-to-Fly 7 Aug 20, 2009 09:36 AM
Discussion What is best Venom Pro Charger X Triton EQ floydbh Batteries and Chargers 1 Aug 15, 2009 03:46 PM
