Aug 21, 2019, 09:03 PM
No my throttle hold is on Switch H,
I was pressing trainer i,
I was getting ready to make a video of the resuce.
But it didnt get to second pack
Originally Posted by Indokast
sounds like you hit throttle hold instead of rescue
Aug 23, 2019, 03:11 AM
So i did a factory reset on the spirit and started over
Started a new model on my TX
Question: What am i supposed to have for channel 5?? What switch? Or is it supposed to be linked with anything?
Question . Under diagnostic tab, should i have 0% for gyro? I dont have any switch assigned to gyro, i am using the “stabi funtion” Switch for rescue. Not negative gyro methods.
When i press Switch I, + rescue pops up under gyro, head lock, but it still remains 0%
Aug 23, 2019, 04:56 PM
Anyone??
Aug 24, 2019, 05:42 AM
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
You need to program a value to gyro in the Tx, start at around +40%.
For initial flights it helps to map the gyro channel to a knob so you can adjust quickly in flight.
Aug 24, 2019, 06:10 AM
And i dont have to put negative value anywhere right? The fbl will take care of that? Since i am using “stabi function” on a switch??
Also what about channel5:gear? Should that be inactive under channel assign?
I attached some pictures on my last posts
Aug 24, 2019, 06:18 AM
You need to assign channel 5
Aug 24, 2019, 06:26 AM
It is assigned to gear, but no switch assigned to that?
Check photos below
Aug 25, 2019, 10:31 AM
Here is video of the complete dx9 setup and swash movement
Blade Fusion 270, Spirit FBL, Spektrum DX9 setup (3 min 54 sec)
Aug 28, 2019, 07:56 AM
Cyclone 7's Avatar
Edit
Aug 28, 2019, 08:28 AM
if he compared the tail grips to his other 270, he would have found out they were reversed.. but because nobody mentioned it to him, he didn't do it...
another thing, why would he try rescue if the heli wasn't flying correctly?
all posted on another site... far from over.
Aug 28, 2019, 09:03 AM
And over, and over and over...……..
Aug 28, 2019, 09:10 AM
Cyclone 7's Avatar
Originally Posted by linemen120
How’s that possible? He’s been flying for 10 yrs
Apparently not - that small detail has now changed to five years over on the other site
https://www.helifreak.com/showthread.php?t=840939
Aug 28, 2019, 09:35 AM
its apparent that lies, when kept ongoing, and have gone in a complete circle, even the person that's telling them, believes them.
its also been posted that he needs to learn how to walk before he can run, but is still learning to crawl.
Aug 28, 2019, 10:32 AM
☆ OVERDISCHARGE MASTER ☆
Flying Pitcher's Avatar
What are you talking about? Guy cn hover inverted without even looking. Took me like 3 yrs to stay inverted.
Aug 28, 2019, 10:44 AM
I learned very early in life that if you always tell the truth, you will NEVER forget what you said. That has served me well throughout my 67 years.
News Blade Fusion 270 BNF Helicopter Jason Cole Electric Heli Talk 472 Today 02:48 PM
Discussion Spirit fbl help!! alibaloch94 Electric Heli Talk 10 Aug 18, 2019 08:16 PM
New Product New Blade - Fusion 270 Helicopter with SAFE jakeaheli Micro Helis 27 Sep 21, 2018 06:51 PM
Discussion Need help setting up swash plate of Fusion 270 azaz44 Mini Helis 4 May 15, 2018 09:17 AM
Discussion NEW heli from Blade...Fusion, belted tail, 270 size Yen Electric Heli Talk 3 Feb 02, 2018 03:39 PM
