Aug 16, 2019, 11:27 AM
New Product
tarot miao 550 helicopter
today i am receive the tarot miao 550 helicopter
today i am first show product picture
first the product is have more intimate
you can look the the parts install where manual and server wire
now i am no have time made install video
the product link now this website is free ship
https://www.tarot-rc.com/tarot-miao-...n-mk55a00.html
Aug 16, 2019, 11:33 AM
rc user
pdooley's Avatar
nice, but what is the "300" tail servo?
Aug 16, 2019, 11:41 AM
i think this is Rendering picture
the he website Electronic suit is use
SUIT A:
KST BLS815X high pressure brushless digital steering gear 3(CCPM)
KST BLS805X high voltage brushless digital narrow frequency servo 1(LOCK TAIL)
EGODRIFT 4035HS/6S/1090KV motor 1
Tarot rectifier head cover 1
https://www.tarot-rc.com/tarot-miao-...ione-mk55.html
but the SUIT A is expensive
so i am found cheap Electronic parts
Aug 16, 2019, 12:27 PM
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Nice, I've been flying a prototype version of the 600 for the last couple of months. It's a great heli!
PS.. does anyone know what 'Miao' translates to in English? Google translate doesnt recognise the word.
Aug 16, 2019, 12:50 PM
rc user
pdooley's Avatar
i checked, came up with this:
https://www.google.com/search?q=miao...hrome&ie=UTF-8
Aug 16, 2019, 01:21 PM
Cool, so it's a name of a place and the people who live there.. So there is no translation as such.
Apparently it's pronounce Meow.. as in the noise a cat makes.
Aug 16, 2019, 01:35 PM
Cyclone 7's Avatar
I believe that it is being used in this context;
A feminine given name, meaning "wonderful, clever, ingenious, excellent" - if written with the Hanzi 妙 (mio).
Aug 16, 2019, 01:58 PM
Woga65's Avatar
The noise of a kitten?
Aug 16, 2019, 02:18 PM
I'm confused now.. Apparently it can translate to 'Wonderful' too and be pronounced more like Me-ah:
https://www.wordhippo.com/what-is/th...e03bdbcf5.html
Aug 16, 2019, 04:18 PM
☆ OVERDISCHARGE MASTER ☆
Flying Pitcher's Avatar
Yes.
Neon green looks so cool!
Aug 16, 2019, 08:19 PM
the miao is Chinese 妙 pinyin
Aug 16, 2019, 08:20 PM
are u use what Electronic equipment
Aug 17, 2019, 02:46 AM
Motor: Scorpion HKIII 4035 560Kv (11t pinion)
ESC: HW Platinum 130A HV
Servos: KST BLS815 / 805X
FBL: Spirit pro
Receiver: Jeti R3L
A few build notes:
  • Be aware that the plastic surrounds for the servos wont fit all servos. Some may require the small plastic 'bridge' that goes over the servo to be removed.. This doesnt effect function at all.
  • The motor mount on my prototype (may have changed on production models?) was drilled for M3 screws, which will be ok for smaller motors. My Scorpion needed M4 so i drilled them out, this is very easy.
  • The manual i was using (early version) suggested cutting the motor wires short. I do not recommend doing this as they are very hard to re-solder. The standard wires fit just fine, so no need to do it.
  • Use CA glue on the balls that screw into plastic. Only gently tighten to avoid stripping threads, the CA prevents them coming out so no need to be very tight.
  • Take care not to over-tighten the tail blade bolts, if you do it can cause the plastic tail grips to crack.
Aug 17, 2019, 03:39 AM
Cyclone 7's Avatar
Call me a philistine if you will but I still can't get the image of a 'Fun Scale' Apache AH-64 fuselage wrapped around the Miao, out of my mind
Aug 17, 2019, 10:44 AM
Sacrilege
Discussion All new and very 'different' 550/600 heli from Tarot JetPlaneFlyer Electric Heli Talk 1112 Today 07:25 PM
Discussion Tarot 550/600 Manual Downloads Cyclone 7 Large Electric Helis 9 Jul 09, 2019 03:42 PM
Discussion Tarot 550/600 FBL rotor housing TL60231 pdooley Large Electric Helis 8 Dec 02, 2016 12:37 PM
