Aug 17, 2019, 01:28 PM
Originally Posted by I TOBOR
It actually has a groove in it and the pump rod is worn rounded as has started in the one you show.
The 90-T had a different pump.
Oh ok. Too bad they couldn't have moved the pump dive pin closer to the cam gear. The intake lobe is much wider, that way the pump pin could run in its own path on the cam lobe.
I like that vane pump idea better. Would have been a bit more complicated to incorporate into the 130 design, if not impossible.
Aug 17, 2019, 03:44 PM
Systems Test Engineer Amateur
Gary Cee's Avatar
The 90T may indeed have gone to the vane type pump.
However, the diaphragm pump was returned when the 100 came out.
Never had a problem with them.
Aug 18, 2019, 05:58 AM
I TOBOR's Avatar
I passed this 100 on to the Wasper, it had no pump.
Aug 18, 2019, 08:21 AM
Gary Cee's Avatar
Yep I passed the new in box 100 ABC on to a fellow at RCU. It did have the pump. Saito later did away with the pumps. So really, the pump problem isn't a problem after all
Question 1/4 or 1/5 Sig Cub w/Saito 130 twin advice Redjack Engines 40 Mar 11, 2018 04:49 PM
Help! Sig 1/4 scale cub / Saito 130 twin mount problem Redjack Giant Scale Airplanes 11 Aug 20, 2015 10:18 AM
Question 1/4 or 1/5 Sig Cub w/Saito 130 twin? Redjack Giant Scale Airplanes 2 Feb 28, 2015 12:39 PM
Help! 1/4 or 1/5 Sig Cub w/Saito 130 twin? Redjack Fuel Plane Talk 2 Jan 19, 2015 09:27 AM
Discussion Saito 130 twin Cumbernauld Fuel Plane Talk 3 Jan 06, 2009 08:16 AM
