Aug 15, 2019, 07:35 AM
Thermals, Tom
RyanNX211's Avatar
Commercially available rotor blades
If someone told me they had a better wing for my airplane, I just wouldn’t go strap it on.
At a minimum, I’d have to check the chord and incidence.
But some rotor blades look crude. Maybe the plans just give the modeler something simple to make. Take the FA-61 in Model Builder (Clark Y) or the Synchro Gyro and DB Autogyro.
Could these be improved with an autogyro designed airfoil?
https://www.ebay.com/itm/Tragschraub....c100689.m4649
Latest blog entry: Steak and Old Timers
Aug 17, 2019, 06:45 PM
Thermals, Tom
RyanNX211's Avatar
"Anyone, anyone" teacher from Ferris Bueller's Day Off (1 min 16 sec)
Aug 22, 2019, 02:50 PM
It's all in the Blades!
SafeLandings's Avatar
Absolutely,
The DB Gyrace shows two versions on the plan, the standard 4 blade using flat sheet. The alternative is a 3 blade with Aerofoil sections.
A few years ago Jodini converted his Gyrace and put 3 blade aerobalsa blades attached to delta 3 flapping head plates.
I can't find the thread now but it flew better than the original as they produced more lift.
Aug 22, 2019, 03:27 PM
Back in the day I used airfoil blades on my Gyrace as well over the stock flat slat type blades. Much improved flight performance.
Aug 22, 2019, 05:16 PM
Thermals, Tom
RyanNX211's Avatar
Got to look up this Gyrace. What would happen if he kept the hub and added 4 airfoiled blades?
Aug 23, 2019, 06:43 AM
More lift/drag I would expect
Discussion Commercially available 60" Pitcherong/Wingeron kits cgraf Slope 13 Jun 04, 2019 05:11 PM
Discussion What's currently the best supercapacitor commercially available? QuadrupleQ Batteries and Chargers 6 Mar 08, 2018 09:55 PM
Discussion Multi-Rotor Commercial Use Registration (HELP!!!) RCJayhawk2015 Commercial UAV/FPV 1 Jan 04, 2016 04:04 PM
Question Are 30-40mm opposite pitch fan blades (ie L & R) commercially available? ShaKaan Micro EDF Jets and Power Systems 15 Oct 04, 2012 01:38 PM
Discussion Are there any 450 size commercially available flapping hinge 3 blade heads??? j_js1 Coaxial Helicopters 1 May 02, 2009 11:50 AM
