Aug 14, 2019, 06:48 AM
"Come and take it B'yatch"
flashted's Avatar
Help!
Trifecta issues
Hello,
I need some help with some on the ground Tail servo jitter in Triflight. I have looked at other vids, and it seems to be a common issue. It could be a filter issue from what others have said. I do have the servo feed back wire, and done the tail tune, but need some suggestions. It oscillates slightly also, and need advice of where to start in the PID's. I do have screenshots of the PIDS as it sits, and will post them. Its running a Matek F405 Mini, and Triflight.
Here is a video of it on the ground, and flying.
Trifecta issues (5 min 12 sec)
# version
# Triflight on Betaflight 3.2.2 v2 / MATEKF405 (MKF4) 3.2.2 Dec 31 2017 / 15:24:22 (30f68c8) MSP API: 1.36
# master
set align_gyro = DEFAULT
set gyro_lpf = 42HZ
set gyro_sync_denom = 1
set gyro_lowpass_type = PT1
set gyro_lowpass_hz = 90
set gyro_notch1_hz = 400
set gyro_notch1_cutoff = 300
set gyro_notch2_hz = 200
set gyro_notch2_cutoff = 100
set moron_threshold = 48
set gyro_use_32khz = OFF
set align_acc = DEFAULT
set acc_hardware = AUTO
set acc_lpf_hz = 10
set acc_trim_pitch = 0
set acc_trim_roll = 0
set baro_bustype = I2C
set baro_spi_device = 0
set baro_i2c_device = 1
set baro_i2c_address = 0
set baro_hardware = AUTO
set baro_tab_size = 21
set baro_noise_lpf = 600
set baro_cf_vel = 985
set baro_cf_alt = 965
set mid_rc = 1500
set min_check = 1050
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 41
set rssi_invert = OFF
set rc_interp = AUTO
set rc_interp_ch = RP
set rc_interp_int = 19
set fpv_mix_degrees = 0
set max_aux_channels = 14
set serialrx_provider = SBUS
set sbus_inversion = ON
set spektrum_sat_bind = 0
set spektrum_sat_bind_autoreset = ON
set airmode_start_throttle = 1350
set rx_min_usec = 885
set rx_max_usec = 2115
set serialrx_halfduplex = OFF
set input_filtering_mode = OFF
set blackbox_p_ratio = 32
set blackbox_device = SDCARD
set blackbox_on_motor_test = OFF
set blackbox_record_acc = ON
set min_throttle = 1070
set max_throttle = 2000
set min_command = 1000
set dshot_idle_value = 450
set use_unsynced_pwm = OFF
set motor_pwm_protocol = ONESHOT125
set motor_pwm_rate = 480
set motor_pwm_inversion = OFF
set thr_corr_value = 0
set thr_corr_angle = 800
set failsafe_delay = 4
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_kill_switch = OFF
set failsafe_throttle_low_delay = 100
set failsafe_procedure = DROP
set align_board_roll = 0
set align_board_pitch = 0
set align_board_yaw = 0
set gimbal_mode = NORMAL
set bat_capacity = 0
set vbat_max_cell_voltage = 43
set vbat_full_cell_voltage = 41
set vbat_min_cell_voltage = 33
set vbat_warning_cell_voltage = 35
set vbat_hysteresis = 1
set current_meter = ADC
set battery_meter = ADC
set vbat_detect_cell_voltage = 30
set use_vbat_alerts = ON
set use_cbat_alerts = OFF
set cbat_alert_percent = 10
set vbat_cutoff_percent = 100
set vbat_scale = 110
set ibata_scale = 400
set ibata_offset = 0
set ibatv_scale = 0
set ibatv_offset = 0
set beeper_inversion = ON
set beeper_od = OFF
set beeper_frequency = 0
set beeper_dshot_beacon_tone = 0
set yaw_motors_reversed = OFF
set 3d_deadband_low = 1406
set 3d_deadband_high = 1514
set 3d_neutral = 1460
set 3d_deadband_throttle = 50
set servo_center_pulse = 1500
set servo_pwm_rate = 300
set servo_lowpass_hz = 0
set tri_unarmed_servo = ON
set channel_forwarding_start = 4
set tri_unarmed_servo = OFF
set tri_tail_motor_thrustfactor = 54
set tri_tail_servo_speed = 274
set tri_servo_feedback = RSSI
set tri_motor_acc_yaw_correction = 0
set tri_motor_acceleration = 18
set tri_dynamic_yaw_boost = 240
set tri_servo_max_angle = 40
set reboot_character = 82
set serial_update_rate_hz = 100
set accxy_deadband = 40
set accz_deadband = 40
set acc_unarmedcal = ON
set imu_dcm_kp = 2500
set imu_dcm_ki = 0
set small_angle = 25
set auto_disarm_delay = 5
set disarm_kill_switch = ON
set gyro_cal_on_first_arm = OFF
set gps_provider = UBLOX
set gps_sbas_mode = WAAS
set gps_auto_config = ON
set gps_auto_baud = OFF
set gps_wp_radius = 200
set nav_controls_heading = ON
set nav_speed_min = 100
set nav_speed_max = 300
set nav_slew_rate = 30
set fixedwing_althold_reversed = OFF
set alt_hold_deadband = 40
set alt_hold_fast_change = ON
set deadband = 10
set yaw_deadband = 10
set yaw_control_reversed = OFF
set pid_process_denom = 1
set tlm_switch = OFF
set tlm_inverted = OFF
set tlm_halfduplex = ON
set frsky_default_lat = 0
set frsky_default_long = 0
set frsky_gps_format = 0
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set hott_alarm_int = 5
set pid_in_tlm = OFF
set report_cell_voltage = OFF
set ledstrip_visual_beeper = OFF
set sdcard_dma = OFF
set osd_units = IMPERIAL
set osd_rssi_alarm = 20
set osd_cap_alarm = 2200
set osd_alt_alarm = 100
set osd_ah_max_pit = 20
set osd_ah_max_rol = 40
set osd_tim1 = 2560
set osd_tim2 = 2561
set osd_vbat_pos = 2391
set osd_rssi_pos = 40
set osd_tim_1_pos = 54
set osd_tim_2_pos = 33
set osd_flymode_pos = 333
set osd_throttle_pos = 225
set osd_vtx_channel_pos = 377
set osd_crosshairs = 2248
set osd_ah_sbar = 200
set osd_ah_pos = 200
set osd_current_pos = 385
set osd_mah_drawn_pos = 353
set osd_craft_name_pos = 362
set osd_gps_speed_pos = 2263
set osd_gps_lon_pos = 82
set osd_gps_lat_pos = 65
set osd_gps_sats_pos = 2104
set osd_home_dir_pos = 2093
set osd_home_dist_pos = 2094
set osd_compass_bar_pos = 266
set osd_altitude_pos = 2295
set osd_pid_roll_pos = 423
set osd_pid_pitch_pos = 455
set osd_pid_yaw_pos = 487
set osd_debug_pos = 1
set osd_power_pos = 321
set osd_pidrate_profile_pos = 345
set osd_warnings_pos = 329
set osd_avg_cell_voltage_pos = 76
set osd_pit_ang_pos = 257
set osd_rol_ang_pos = 289
set osd_battery_usage_pos = 392
set osd_disarmed_pos = 138
set osd_nheading_pos = 311
set osd_nvario_pos = 2327
set osd_esc_tmp_pos = 82
set osd_esc_rpm_pos = 83
set osd_stat_max_spd = ON
set osd_stat_max_dist = OFF
set osd_stat_min_batt = OFF
set osd_stat_min_rssi = OFF
set osd_stat_max_curr = ON
set osd_stat_used_mah = ON
set osd_stat_max_alt = ON
set osd_stat_bbox = OFF
set osd_stat_endbatt = OFF
set osd_stat_bb_no = OFF
set osd_stat_tim_1 = OFF
set osd_stat_tim_2 = OFF
set task_statistics = ON
set debug_mode = TRI
set cpu_overclock = OFF
set pwr_on_arm_grace = 5
set vtx_halfduplex = ON
set vcd_video_system = 2
set vcd_h_offset = 0
set vcd_v_offset = 0
set max7456_clock = DEFAULT
set displayport_msp_col_adjust = 0
set displayport_msp_row_adjust = 0
set displayport_max7456_col_adjust = 0
set displayport_max7456_row_adjust = 0
set displayport_max7456_inv = OFF
set displayport_max7456_blk = 0
set displayport_max7456_wht = 2
set esc_sensor_halfduplex = OFF
set led_inversion = 0
set dashboard_i2c_bus = 1
set dashboard_i2c_addr = 60
set camera_control_mode = HARDWARE_PWM
set camera_control_ref_voltage = 330
set camera_control_key_delay = 180
set camera_control_internal_resistance = 470
# profile
profile 2
set dterm_lowpass_type = BIQUAD
set dterm_lowpass = 100
set dterm_notch_hz = 260
set dterm_notch_cutoff = 160
set vbat_pid_gain = OFF
set pid_at_min_throttle = ON
set anti_gravity_threshold = 350
set anti_gravity_gain = 1000
set setpoint_relax_ratio = 100
set dterm_setpoint_weight = 0
set acc_limit_yaw = 100
set acc_limit = 0
set crash_dthreshold = 50
set crash_gthreshold = 400
set crash_setpoint_threshold = 350
set crash_time = 500
set crash_delay = 0
set crash_recovery_angle = 10
set crash_recovery_rate = 100
set crash_limit_yaw = 200
set crash_recovery = OFF
set iterm_windup = 50
set iterm_limit = 150
set pidsum_limit = 500
set pidsum_limit_yaw = 400
set yaw_lowpass = 0
set p_pitch = 58
set i_pitch = 50
set d_pitch = 35
set p_roll = 40
set i_roll = 40
set d_roll = 30
set p_yaw = 70
set i_yaw = 45
set d_yaw = 20
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 50
set i_level = 50
set d_level = 75
set p_vel = 55
set i_vel = 55
set d_vel = 75
set level_limit = 55
set horizon_tilt_effect = 75
set horizon_tilt_expert_mode = OFF
set gps_pos_p = 15
set gps_pos_i = 0
set gps_pos_d = 0
set gps_posr_p = 34
set gps_posr_i = 14
set gps_posr_d = 53
set gps_nav_p = 25
set gps_nav_i = 33
set gps_nav_d = 83
# rateprofile
rateprofile 0
set rc_rate = 100
set rc_rate_yaw = 100
set rc_expo = 0
set rc_expo_yaw = 0
set thr_mid = 50
set thr_expo = 0
set roll_srate = 70
set pitch_srate = 70
set yaw_srate = 70
set tpa_rate = 10
set tpa_breakpoint = 1650
# get master
Invalid name
Aug 14, 2019, 01:02 PM
Tail jitter in Trifecta, a pandemic disease. Some medications:
- Install a 1000mF capacitor directly in the PDB battery weldings.
- Increase values for RC deadband and Yaw deadband.
- Redo the endpoints servo calibration with eagle eye.
- Install a good digital servo with metal gears.
- Use teflon tape on the Trifecta yaw pinions to ensure a tight but free function.
Whit this old glory you will have several hours of tuning PIDS. While quads calibration are very straightforward, tricopters (especially the plastic framed ones) need a very precise PIDs calibration you will only reach whit lot of trial and error.
Aug 14, 2019, 09:16 PM
flashted's Avatar
Thanks for the suggestions
I have already done most of what you have suggested.
I forgot what the rating is on the cap though.
I will increase values for RC deadband and Yaw deadband next
Cheers
Ted
Aug 14, 2019, 09:21 PM
flashted's Avatar
PS the arms on this Trifecta have been modded with carbon fiber. 5mm cap strips along the outside of the front arms, although they are not visible.
I used to do Tricopters with KK boards, but the Betaflight/Triflight stuff is a different animal.
Aug 15, 2019, 04:46 PM
USAF Vet Senior Member
peterv's Avatar
Just had jitter pop up on mine. Balanced all props and jitter is gone. Then the servo died! What a pain to change.
Aug 15, 2019, 06:58 PM
flashted's Avatar
This is a jitter as it sits idle, in the tail servo. Yes big pain to change it. I have a digital in it now called a Dymond DD 150, with a feed back wire, and an emax w feedback wire waiting in the wings, but I am trying to get it to stop with the existing servo. It flys pretty good, but the jitter on the ground is an annoyance. I don't see David Windenstal's tri's doing it, do I know it can be figured.
Aug 16, 2019, 04:34 PM
peterv's Avatar
Set this to OFF and unarmed jitter will go!
Aug 16, 2019, 10:06 PM
flashted's Avatar
Will do peterv, will try it tonight, and get back to you.
t really is just an annoyance, but Im like that. I just don't like it when things are odd.
Thank you
Aug 16, 2019, 10:16 PM
flashted's Avatar
I think the uneven start in part could be a CG issue, although the motors do not all start together when I throttle up. I am running little bee esc's, with the later BL Heli firmware, and will try re calibrating everything again to see if it helps, but i've done this before to no avail.
I am running a 2100 ma 3s lipo, which the instructions say is fine, and Quanum supplies a foam block to accommodate this.
Aug 17, 2019, 09:48 AM
peterv's Avatar
I run 1300ma 3s or 4s with 5 min flight times. 5s4 props 2 blade. It is a rocket on 4s.
Help! Quanum Trifecta-Servo issue Scoutboydias Tricopter Drones 2 Oct 06, 2016 12:23 PM
Help! Quanum Trifecta advice Mekinizem Multirotor Drone Talk 1 Jul 31, 2016 07:14 AM
Help! Trifecta naze32 with turnigy 9x yousufwalton Tricopter Drones 4 Jan 18, 2016 07:06 PM
Discussion Making a beast quanum trifecta FlyingPancake Tricopter Drones 37 Dec 02, 2015 06:38 PM
