Sep 18, 2019, 08:55 AM
Interesting glue, I'll check that out. Here's the connectors for square sections.
https://dragonplate.com/Modular-Carb...ube-Connectors
Sep 18, 2019, 02:43 PM
I'll have to check into that glue. Here's the link to the connectors.
Sep 20, 2019, 11:10 AM
I'll have to check out that glue, has to be pretty strong. Here's the link to the connectors.
Sep 20, 2019, 11:17 AM
Sure wished that I could figure out how to delete a post!! Damn
Sep 20, 2019, 11:21 AM
Cool - the glue is no joke- gets the best bond so far on CF that I've seen. Too bad those connectors are one size too big for me lol. I had an idea about using that Iflight DC10 frame but dumping the arms that come with it for the 10mm carbon- you could make it a dc15 if you wanted and the arms are only 2mm thicker so all you'd have to replace would be the bottom plate screws. You'd have to use some basswood (3/8 or 5/16 fits perfect) inside the cf tubes where the arms bolt through the frame so the tube doesn't crush. Matter of fact this idea would probably work on MOST frames with a bottom/mid plate setup that clamps the arms in place. I'll probably use some form of this for my next build, along with those low kv sunnyskys.
Sep 20, 2019, 04:56 PM
Okay so just bought this Beast today. Supposed 50 minute run time, probably 30 LOL. If a battery this size can power a lawn mower for 30 minutes under pressure why can't it power 4 relatively small comparatively speaking quadcopter motors for a Hell of a long time? Just doesn't make sense. Says it has 300Wh
Sep 20, 2019, 05:24 PM
Maybe it can but you'd have to break the voltage down somehow I think 60v is somewhere along the lines of 18 S. Haven't seen too much equipment with that high of rating. Also excess weight may be a factor. Im sure a traditional flight pack has much better power to weight ratio.
Discussion What frame would you put this stuff in? dashunde Mini Multirotor Drones 0 Apr 12, 2018 10:20 AM
Discussion What battery should I use for this 210mm X frame? FredBoucher Beginner Multirotor Drones 28 Nov 18, 2017 05:02 AM
Question What Frame is this one? mahmahmartin Multirotor Drone Talk 0 Nov 01, 2017 05:46 AM
Discussion What frame is this? darthnugget Multirotor Drone Talk 3 Apr 15, 2016 08:50 PM
Discussion Y6 motor layout... what does this 'motor all' screen mean? Top or bottom? porqueno Beginner Multirotor Drones 1 Jan 11, 2016 06:40 PM
