This thread is privately moderated by GroundControlRC, who may elect to delete unwanted replies.
Aug 13, 2019, 07:45 AM
Video
Tutorial - King Kong/LDARC Tiny Wing 450 Installing the FPV System
Here is a link to the Video:
https://www.youtube.com/watch?v=_mO4nYYZ1W8
This item is courtesy of Banggood.
I thought this Tiny Wing would make for an excellent Micro FPV Wing ;-)
It has several flight modes; 6-axis, 3-axis, and manual.
It's made from EPP Foam which should make it extremely durable ;-)
I installed a Micro FPV System and with the 2S 450mah 35C LIPO I use it puts the CG (Neutral Balance) as far foward as 120mm from the Nose which is right where it needs to be ;-)
This FPV System worked out very well and kept the AUW at only 105 grams ;-)
This is one fun little Micro FPV Wing!
Get one today from Banggood!
Here are links to the (2) FPV Test Flights:
https://www.youtube.com/watch?v=NoIdOGNr6i0
https://www.youtube.com/watch?v=6DSuuAX6PDo
Here is a link to the Micro AIO FPV Camera:
Turbowing 5.8G 48CH 25mw 700TVL 1/4 CMOS Wide Angle FPV Camera Support OSD NTSC/PAL Switchable
https://www.banggood.com/48CH-25mw-T...47791920140372
Here is a link to the SBEC (Switching Voltage Regulator):
Pololu 3.3V, 300mA Step-Down Voltage Regulator D24V3F3
https://www.pololu.com/product/2097
Here is a link to this Cool Micro Wing:
KINGKONG/LDARC TINY WING 450mm Wingspan EPP FPV PNP With Flight Control
https://www.banggood.com/KINGKONGLDA...47791920140372
Here is a link to the Micro SBUS DSM2/DSMX Receiver I used:
(Note: I changed the connector on the Flight Controller & Receiver to a Servo Connector)
MOY DS801 DSMX DSM2 Mini Compatible Receiver with SBUS PPM Output
https://www.banggood.com/MOY-DS801-D...47791920140372
Here are links to some LIPOs that should work as I could not find the LIPO I used:
(Note: This is based on the stated Spec/Dimensions/Weight of the LIPOs, I do not have these so I cannot confirm this is accurate)
Gaoneng GNB 7.4V 450mAh 2S 80C/160C Lipo Battery JST Plug
https://www.banggood.com/Gaoneng-GNB...47791920140372
URUAV 7.4V 450mAh 80/160C 2S Lipo Battery JST Plug for RC Drone
https://www.banggood.com/URUAV-7_4V-...47791920140372
KINGKONG/LDARC FLY EGG V2 100 RC FPV Racing Drone Spare Part 7.4V 450mAh 80C Lipo
https://www.banggood.com/KINGKONG-LD...47791920140372
See you in the Air!
See Us On Youtube | Patreon | RCGroups
