This thread is privately moderated by VicT, who may elect to delete unwanted replies.
Aug 12, 2019, 02:26 AM
Conscendo Walrus comparison
My flying buddy has a stock CA and a Walrus that he uses for thermal soaring and for full throttle aerobatic practice and experimentation. He was using a Timber X for aerobatic practice but it’s in need of major foam repairs. The CA is holding up to this type of stress with minor foam cracks and tears glued back with regular CA. He uses the CA SAFE System for “orientation recovery “.
The Walrus is about half the price and does not come with a RX so he is using an orange 5 CH RX for motor, rudder, elevator, ailerons, and flaps. The Walrus does not look like it would be a good sailplane because the fuselage is much fatter than the CA. However the Walrus is stiffer and there is less wing flexing. Walrus has a thinner wing section and with upswept wing tips has better rudder only roll coupling. The glide is faster and has better lift even without changing wing camber. The power to weight and aerobatics are better than the stock CA. The flaps offer full trailing edge camber with ailerons and can slow Walrus down unlike the CA. The Walrus prop shows stress marks and if it fails/seperates could cause a serious body injury during a power on hand launch. The Walrus would be a nice inexpensive aerobatic trainer/motor glider with the Timber X receiver in her. I'll be on the lookout for the similar looking but discontinued ELuna from Tower Hobbies.
Discussion HK Walrus 1400 robert4343 Electric Sailplanes 2 Apr 15, 2016 07:14 PM
Help! Decision: parkzone radian or HK walrus/phoenix 1600 vincesd Beginner Training Area (Aircraft-Electric) 22 Mar 29, 2016 07:40 PM
Discussion Phoenix 2000 vs Walrus 1400 robert4343 Electric Sailplanes 0 Mar 24, 2016 06:23 AM
Help! Decision: parkzone radian or HK walrus/phoenix 1600 vincesd Electric Sailplanes 3 Mar 23, 2016 10:06 PM
Question Cheaper electic glider ? HK Walrus/ST Fox? sirrraftsalot Electric Sailplanes 5 Oct 17, 2015 07:42 PM
