Aug 16, 2019, 12:41 PM
nhk750's Avatar
Also, I forgot, I am using a Power 32 motor and Eflight 60amp ESC on 4s battery with a 12x8 prop and it puts out 750watts pulling 45-50amps in a 60 inch wingspan low wing 5lb sport plane. Just for reference, I think it is close to the Rimfire motor you are using.
Aug 20, 2019, 09:03 PM
I did a thread on converting the SSE a couple of years ago. Perhaps it could be of help to you. John https://www.rcgroups.com/forums/show...omething-Extra
Sep 02, 2019, 08:22 PM
Go Skins
Bchoper's Avatar
Thanks for all the help guys! Got it up and flying this weekend and it flew awesome! Went with Rimefire 32, plush 60 ESC, 4s 3000mah batteries, and 12x8 prop. Unlimited vertical and butter smooth.
Thanks again!
Sep 02, 2019, 08:24 PM
Go Skins
Bchoper's Avatar
Electric Sig Somethin Extra
Pics
Sep 02, 2019, 10:06 PM
Looks good choper. I like the checker board. John
Sep 02, 2019, 10:59 PM
nhk750's Avatar
Nice!
Sep 17, 2019, 06:12 PM
I just want to go fly!
walter3rd's Avatar
Always use a watt meter to test your setups
Sep 18, 2019, 06:42 AM
Crash and Build
dpoles's Avatar
I am just starting the fuse on mine. Could you post detailoed pictures of your hatch setup.
Figuring that out is my next step
thanks
I am stealing the checkerboard idea!
And Yes, the rear of the fuse is a bit busted up in this old kit. I am scratchbuilding certain sections damaged in a move.
The tail feathers are all scratchbuilt.
How did your CG work out? Should I build either end heavy?
Sep 18, 2019, 09:41 AM
Crash and Build
dpoles's Avatar
How is the prop clearance with original gear?
I was planning on 14"- might have to go with 12" and see how many amps I get
Review RCGroups Review of the SIG Somethin' Extra Mean Joe Vermillion Electric Plane Talk 36 Jan 10, 2019 11:11 AM
Discussion Sig Somethin Extra Commander Starx Beginner Training Area (Fuel) 10 Jun 24, 2016 09:38 PM
Discussion SIG Somethin Extra Engine Size VegasRC1 Power Systems 5 Jan 09, 2016 09:07 PM
Discussion SIG SOMETHIN EXTRA ARF Wing tube and somethin amazing . Hobie Fuel Plane Talk 20 May 25, 2007 04:22 PM
