Aug 09, 2019, 11:22 AM
FPV with the lightweight 35" VA Zeta wing from Twisted Hobbies
The VA Zeta is a model typically used for line-of-sight acrobatic or combat flight, but with a simple lightweight FPV camera the Zeta turns into a great first-person flight model.
VA Model's Zeta 35" EPP Wing now available at Twisted Hobbys. (1 min 5 sec)
The 35" (900mm) wing with a camera and battery only weighs about 250g - it's light weight construction and EPP foam make it very durable which is great for beginners and aggressive advanced flying. The Zeta is simple to assemble and the fuselage has plenty of room for the ESC, battery and radio receiver. It's large control surfaces and overall light weight make it much more acrobatic than most other wings.
For this build I used the TW Zorro/Zeta electronics kit (found here: https://twistedhobbys.com/power-comb...-wing-tmw-ice/) which suits the model well. I used an APC 7x4 prop to better match the 3S battery I used. With a small ~500mah 3S the Zeta has plenty of power for vertical climbs but is also very stable at low speed which is great for proximity flying and smaller flying areas.
There is plenty of space on the model to install an FPV camera. I installed my camera in a small hole cut 2" to the left of the nose to better avoid any damage in crashes. A 25mw FPV camera can be powered from an empty 5v servo port on your radio receiver - a 200mw camera can be installed to increase FPV range, but a separate BEC or small 1S lipo battery should be used.
The Zeta is available at twisted hobbies along with other FPV models including models from ZOHD:
https://twistedhobbys.com/va-models/
https://twistedhobbys.com/zohd/
Build video of the VA Zeta:
VA Model's 35" EPP Zeta Wing Build Video (8 min 3 sec)
Aug 09, 2019, 05:44 PM
Twisted Realm's Avatar
Looks sharp James!
Discussion Twisted Hobbys - TELINK Toro 900 - 35" EPP Wing cdee Flying Wings 82 Aug 23, 2020 08:47 AM
New Product Sky Observer (Skylark) 2m FPV Wing from ZETA wabu66 FPV Aircraft 101 Feb 10, 2020 03:54 PM
Build Log VA-Models 36" Christen Eagle 2 EPP Full Fuse from Twisted Hobbys AJWoods 3D Foamies 10 Nov 07, 2018 02:09 AM
Discussion Twisted Hobbys / VA Models - Nieuport 17 cdee Scale ARF/RTF 8 Oct 31, 2018 07:49 AM
Help! Lightweight led system for twisted Hobbies puddlestar fairplane Night Flying 3 Apr 02, 2017 08:45 PM
