This thread is privately moderated by scousethief, who may elect to delete unwanted replies.
Aug 08, 2019, 01:33 PM
Quad Erat Demonstrandum
scousethief's Avatar
Cool
Upgrade Happymodel Mobula7 HD 2-3S 75mm Crazybee
https://www.banggood.com/custlink/vKGK9aCKj9
12% off coupon: BGMobula7V2
Upgrade Version:
1. Motors are upgraded to 9000KV Version.
2. Removed the Microphone and it was packed separately in the pacakge.
3. Heighten the frame
07.29 Beijing Time
Notice:
New betaflight configurator 10.5.0 and 10.5.1 are not compatible for Mobula7 HD very well for now.
We suggest to use Betaflight configurator 10.4.0
In order to reduce risk from the Mobula7 HD (10000kv motor version )esc burnt , we suggest to limit the throttle scales to 75% .
Performance is almost the same like new 9000KV version.
The cli command is :
set throttle_limit_type = scale
set throttle_limit_percent = 75
save
Specification:
Brand Name: Happymodel
Model: Mobula7 HD
Item Name: 75mm Wheelbase 2-3S Brushless Whoop FPV Racing Drone
Wheelbase: 75mm
Receiver ( Optional): Compatible Frsky NON-EU Receiver
Compatible Flysky Receiver
Compatible DSM2/DSMX Receiver
Without Receiver
Weight: 48g (without battery)
72g ( with battery )
Crazybee F4 PRO V2.0 Flight Controller
Item Name: Crazybee F4 Pro V2 FC
MCU: STM32F411CEU6 (100MHZ, 512K FLASH)
Sensor: MPU-6000(SPI connection)
Board size: 28.5 * 28.5MM
Power supply: 1-3S battery input (DC 3.5-13V)
Built-in 5A(each) Blheli_S 4in1 ESC Dshot600 ready
Built-in Receiver ( Diffirent version having diffirent receiver,
without receiver version doesn't have rx)
Built-in Betaflight OSD(SPI Control)
Built-in Current meter Max 28A
Current meter scale set to 1175
Built-in 5V 1A Buck / Boost with LC filter
Built-in voltage detection
Firmware
(Frsky version) CRAZYBEE F4FR PRO V2.0 Firmware target: CrazybeeF4FR
(Flysky version) CRAZYBEE F4FS PRO V2.0 Firmware target: CrazybeeF4FS
(DSM2/DSMX version) CRAZYBEE F4DX PRO V2.0 Firmware target: CrazybeeF4DX
(No RX version) CRAZYBEE F4 PRO V2.0 Firmware target: CrazybeeF4DX
Onboard 5A 4 In 1 ESC
MCU upgraded to EFM8BB21
Power supply: 1-3S LiPo/LiPo HV (3.5v/13v)
Current: 5A continuous peak 6A (5 seconds)
Support BLHeliSuite programmable
Factory firmware: S_H_50_REV16_7.Hex
Default protocol: DSHOT600
Onboard Frsky NON-EU receiver Version
SPI BUS receiver
Frsky D8/D16 switchable
Compatible Non EU transmitter both D8 and D16 mode
Channels: 8ch or 16ch
Failsafe support
No ground interference ( Transmitter and receiver 1 m from the ground): 300m
Onboard Flysky receiver Version
SPI BUS receiver
Protocol: AFHDS and AFHDS-2A Switchable
Channels: 8ch(AFHDS) or 14ch(AFHDS-2A)
Failsafe support
Onboard DSM2 / DSMX receiver version
Serial bus receiver
Protocol: DSM2/DSMX compatible
Channels:6-9 (Depend on your radio)
EX1102 9000KV Motor
Mode: EX1102 KV9000
Configu-ration:9N12P
Stator Diamter:11mm
Stator Length:2mm
Shaft Diameter:Φ1mm
Motor Dimension(Dia.*Len):Φ13.5mm*16mm
Weight(g):2.8g
No.of Cells(Lipo):1S-3S
Propeller
40mm 4-blade Propeller ( 4 CW + 4 CCW)
5.8G 40CH 25-200mW VTX
Output power: 25~200mw switchable
Frequency: 40CH
Input voltage: 3.3V 5.5V
Current consumption: 300mA(type)
Antenna: RG178 antenna
Frequency: 5.8GHz 5bands 40 channels
With Raceband
Smartaudio ready
Weight: 3g
CADDX Turtle V2 Camera
Image sensor: 1/2.7" CMOS sensor
Horizontal: 800TVL
TV system: NTSC/PAL changeable
Video Resolution: [email protected] / [email protected] / [email protected]
Power Input: DC 4.5-20V
FPV FOV: 155
Recording FOV: 170
Mini Illumination: 0.01lux
Image Resolution: 2 Megapixels
Lens: 1.8mm Turbo Eye Lens
Working Current: [email protected]/[email protected] (low consumption)
OSD Menu: Yes (Support Voltage Display)
Video Files: MP4
Audio: Support
Electronic Shutter : PAL : 1/50-100,000 NTSC : 1/60-100,100
S/N Ratio: >60dB (AGC OFF)
Video Output: CVBS
Max Micro SD Card Supported: 8-64GB(need Class 10 or above, recommend Class 10/UHS-I/UHS-II)
Color: Red
Lipo Battery
Capacity:300mAh
Voltage:11.4v
Continuous Discharge Rate: 30C
Instantaneous discharge rate: 60C
Weight: 23g
Connector: XT30
Features:
- New Crazybee F4 PRO V2.0 AIO Flight controller 1-3s Lipo Compatible
- 2S for indoor Cine whoop mode
- 3S for outdoor Freestyle whoop mode
- Betaflight support , multi flight mode: ACRO/AIR/ANGLE
- The lightest 1102 brushless motor only 2.7g with double ball bearings
- Powerful and smoothly
- Betaflight OSD support ,easy to get RSSI, Voltage ,current from your goggles(DSMX version no RSSI output)
- Caddx turtle v2 + 1080p 60fps DVR ready
- Camera Angle adjustable
- VTX power switchable 25mw~200mw
- Smartaudio ready , change VTX bands, powers, channels via OSD
- Frsky Non-EU version support NON-EU Frsky transmitter D8/D16 compatible
- Flysky version support both AFHDS and AFHDS-2A protocol transmitter
- DSM2/DSMX version support DSM2 and DSMX compatible Spektrum transmitter
- No RX version support external serial-bus receiver like xm+, crossfire, S-FHSS etc..
- Full telemetry function ready (Frsky Non-EU and Flysky version support)
- Special Breath light ready
- Real Bind and Fly version
- Compatible both for 2s-3s Lipo/LIHV
Package Included:
1x Mobula7 HD 75mm FPV Drone
4x 40mm 3-Blade Propellers ( 4 CW & 4 CCW)
1x 3S 11.4v 300mah 30C/60C battery
1x Propeller Disassemble Tool
1x Screwdriver
Mobula 7 HD - Cinewhooping in style (5 min 52 sec)
New Product Happymodel Mobula7 HD Version 75mm Crazybee F4 Pro V2.0 FC 3S Whoop FPV Racing Drone scousethief Geekbuying.com 0 May 21, 2019 05:53 AM
Discussion Happymodel Mobula7 HD Version 3S Whoop FPV Racing Drone GeekBuying Geekbuying.com 4 Mar 09, 2019 02:17 PM
