Aug 08, 2019, 09:44 AM
How to build RC FlyboardAir after Franky Zapata ?
Hi,
could you elaborate me on what engines do I need to source to build RC FlyboardAir after Franky Zapata
I visited his website
https://www.zapata.com/en
to find no details
from
https://edition.cnn.com/travel/artic...ard/index.html
"Last Sunday the 40-year-old former jet-ski champion took to the skies above Paris at the Bastille day parade, capturing the world's imagination with a board that can reach an altitude of nearly 500 feet -- with the potential to go much higher -- and a speed of 140 kilometers per hour.
"Zapata spent three years creating Flyboard Air, a jet-powered personal aerial vehicle. The key he says, was being able to place five turbine engines over conventional electric propellers to allow intuitive flight controls designed around the human body.
Since flight time is limited to 10mins I would like to know how did he succeed to cross the La Manche Channel
If you have already started to build alike RC FlyboardAir, let me join your team.
Aug 08, 2019, 11:43 AM
If you are looking to build an RC scale model of the Flyboard, the engines needed will depend on just how big you plan to make it. Control and stability will be very similar to what is on every multi rotor, just find one with 5 motors to steal the controller out of.
Aug 08, 2019, 12:24 PM
how to place
"place five turbine engines over conventional electric propellers
could you forward me to some web links with turbine engines, which can be combined with electric propellers ?
Aug 10, 2019, 10:20 AM
From what little I can see in pictures my guess is he is using jetcat P300 turbines.
Aug 10, 2019, 11:40 PM
Zeeb's Avatar
I believe that I saw something about his "board", which said he was using four P400 JetCats. That's why he had the fuel issue trying to cross the English channel without refueling.
Aug 11, 2019, 11:58 AM
Thank you my friends
I got it finally.
http://www.chiefaircraft.com/jc-p400-pro.html
" Idle RPM: 30000
Max RPM: 98000
Thrust at idle (N): 14
Thrust at idle (lbs.): 3.15
Thrust @ max RPM (N): 397
Thrust @ max RPM (lbs.): 89.25
EGT range (C): 480-750
Pressure Ratio: 3.8
Mass Flow (kg/s): 0.67
Exhaust Gas Velocity (km/h): 2122
Exhaust Gas Power Output (kW): 116.4
Fuel Consumption @ max RPM(ml/min): 1300
Fuel Consumption @ max RPM (kg/min): 1.04
Fuel Consumption @ max RPM (oz/min): 43.96
Fuel Consumption @ idle (ml/min): 200
Fuel Consumption @ idle (kg/min): 0.16
Fuel Consumption @ idle (oz/min): 6.76
SFC @ max RPM (kg/Nh): 0.158
Weight (g): 3650
Weight (lbs.): 8.05
Diameter (mm): 148.4
Diameter (.in): 5.84
Length (mm) incl. starter: 353
Length (.in) incl. starter: 13.9
Operating Conditions:
Maximum Startup Altitude: 2600m (@STP)
Maximum Operating Altitude: 10000m / 32800ft
Fuel: Jet-A1 with 5% oil
Max Axial (Forward) Acceleration: 25G
P400-PRO Turbine Engine, 89 lbs Thrust, by JetCat
Item: JC P400-PRO
Price: $11,999.00
Price if prohibitive but who cares the price if you can fly like a Franky.
and more entries from search engine:
http://www.turbinenshop.com/Turbines/JetCat
http://www.jetcatamericas.com/
JetCat home page
and finally, first working jetpack experiments of 2015
https://hackaday.com/2015/11/09/fina...rking-jetpack/
Aug 12, 2019, 03:12 PM
Good manual on how jet engines do work
https://www.explainthatstuff.com/jetengine.html
still looking for details and images how the flyboard air is made
Aug 12, 2019, 04:03 PM
Pro Hoarder
turbonut's Avatar
Considering he is trying to get government and military contracts I don't think you will find any specific construction data on his system...Trade secret!
Latest blog entry: In flight
Aug 12, 2019, 05:04 PM
in local magazines you can get detailed drawings and detailed description of his aircraft
on the internet you can get Ts of images for FlyboardAir
https://www.bing.com/images/search?q...cw=1129&ch=622
Aug 13, 2019, 03:18 PM
Pro Hoarder
turbonut's Avatar
So you just answered your own post #7
What is the problem?
Aug 13, 2019, 04:13 PM
the problem is always the same
How to build Budget RC FlyboardAir after Franky Zapata
don't expect me to buy 5 x
Item: JC P400-PRO
Price: $11,999.00
to spend $60,000 for 5 jet engines only
There must be other way, other manufacturer of jet engines to cut the budget 10 fold
Do you remember the first two-wheeled self-balancing, battery-powered electric Segway invented by Dean Kamen, priced at $30,000 ?
Today you can buy alike two-wheeled self-balancing, battery-powered electric hoverboard at $300 or less.
So electronics, gyroscope, control system can come from a drone but what we really need is jet engine priced at $200, manufactured for RC community in China.
What makes RC jet engine so overpriced today ?
Can you explain me, what makes the price of RC jet engine to top any other RC product ?
Turbine is just turbine and if manufactured in volume, can make the price to get down.
Segway was the first
Ook, sophisticated gyroscope's levelling control
alike challenge to control 5 jet engines
But who can build jet engines at $100 and at what trust specified ?
(dreaming.....)
Next year we all can fly on our $1,000 flyboards in thin air.
some hints from Internet search
https://www.bing.com/search?q=rc+jet...E7210B2A5B4402
How to build a "TURBO-JET ENGINE" from easy to find materials.
https://www.youtube.com/watch?v=hEy6t5uWg-Y
micro-jet-turbines
look overpriced for RC community
http://modelaircraftcompany.com/news...o-jet-turbines
Aug 13, 2019, 04:26 PM
Home made jet engines by Zeus Team and others
Home made Jet engine - Come Realizzare una Turbina Jet- part 2 (5 min 18 sec)
Home made Jet engine - Come Realizzare una Turbina Jet - Part 1 (6 min 42 sec)
homemade jet engine parts and assembly (7 min 17 sec)
Aug 14, 2019, 06:07 AM
The problem is none of these so called "tin can" turbines work, at their best they are blowlamps. Working turbines are precision made with tight tolerances using specialist materials. Compressors are now often made using multi axis CNC mills while the turbines blades are specialist castings in Inconel and will be failed for a single flaw. All of this costs money even at mass production levels. Costs are already coming down from earlier levels but turbines will never be a cheap buy, your idea of $100 costs are fantasy, a small glow engine costs that and they are much lower tech. At the size of turbine needed for your flyboard the amount of sales will be low so the cost will always be high, no maker will build large amounts in the hope they wil be bought.
Jim
Aug 14, 2019, 07:59 AM
from
Catalog
Categories
Micro Jet Turbines (25)
Turbo-prop Turbines (3)
Helicopter Turbines (6)
Marine Turbines (1)
Price
Range: 1 346,00€ - 57 205,00€
There is a room to cut prices 10 fold, to introduce low cost turbines manufactured in volume quantities
I exactly recall talks when Segway entered a market at skyrocket price
Today you can drive alike vehicle at a pocket money.
Exactly the case with 3D printers.
The first were priced at $Ts
today you can buy small 3D printer at $300
So there is a room for prices of turbines to fall thanks to Franky
Discussion how to build a custom RC Manley R FPV Racing 1 Feb 13, 2018 12:28 PM
Discussion How to Build my own RC Track (check out my sketch) Joselox Car Talk 4 Apr 05, 2017 07:53 PM
Help! I am building an RC plane out of balsa. How do I decide airfoil,wing size , geometry captainteague Scratchbuilt Indoor and Micro Models 6 Dec 23, 2015 03:06 PM
How much charge do your RC/CP2400s take after a flight? Mitch G Batteries and Chargers 10 Dec 18, 2002 02:01 PM
