Aug 08, 2019, 06:38 AM
Pixelpeter's Avatar
Skydio 2 autonomous 4K quadcopter
Show reel of the new Skydio 2:
Skydio 2 test footage 0728 (0 min 56 sec)
specifications:
General
Size with Battery
223 x 273 x 74 mm (l x w x h)
Size without Battery
223 x 273 x 43 mm (l x w x h)
Size of included hard case
297 x 255 x 65 mm (l x w x h)
(case fits: drone, spare propellers, charging
cable, and either 2 batteries or 1 battery and
1 wall adapter.)
Weight (with battery)
775 g
Flight Time
23 minutes
Max Flight Speed (sea level, no wind)
36 mph (fully autonomous)
Max Wind Speed Resistance
25 mph
Max Service Ceiling (above sea level)
15,000 ft density altitude
Operational Temperature Range
-5°C to 40°C
Autonomy System
Main Processor
NVIDIA Tegra X2 SOC
GPU
256-core NVIDIA Pascal™ GPU
CPU
Dual-Core NVIDIA Denver 2 64-bit CPU
Quad-Core ARM®-A57 MPCore
RAM
4GB 128-bit LPDDR4
Obstacle avoidance coverage
Omnidirectional and above/below
Super fisheye lenses for 360° view
3D world model update rate
1 million points
World model-to-action update rate
500 iterations per second
Onboard AI
9 custom deep networks used in flight
User-selectable subjects for tracking
People and motor vehicles
Object tracking and identification
Up to 10 simultaneous objects of interest
Calibration
Automated online calibration of lens
parameters, camera rotations, wind speed,
and air density
Cinematic Skills
Motion Track (relative to subject motion)
Fixed Track (relative to absolute orientation)
One Shots (dronie, rocket, boomerang, and vortex)
Cable cam (single pass, looping, or track)
Wireless & GPS
Range to Phone (line of sight, ideal conditions)
200 m
Range to Beacon (line of sight, ideal conditions)
1.5 km
Range to Controller (line of sight, ideal conditions)
3.5 km
Operating Frequencies
2.4-2.483 GHz
5.18-5.24 GHz
5.725-5.85 GHz
Channel width (Standard WiFi)
20, 40, and 80 MHz
Channel width (Skydio Link™)
5 and 10 MHz
GPS Satellite Constellations
GPS and GLONASS
Primary Camera System
Sensor Type
Sony IMX577
1/2.3” 12.3MP CMOS
Sensor Active Pixels
4056 (H) x 3040 (V)
Lens Aperture
f/2.8
Lens Focal Length
20mm (35mm format equivalent)
Lens Depth of Field
1m - ∞
Shutter Speed
electronic shutter 1 to 1/1920s
ISO Range
video 100-3200
photo 100-3200
Image Signal Processor
Qualcomm QCS605
GPU
Adreno™ 615
CPU
64-bit octa-core Kyro™ 300
DSP
Hexagon™ 685, 2x HVX
Resolution and Modes
3840x2160 30 fps
3840x2160 60 fps
3840x2160 48 fps
3840x2160 24 fps
1920x1080 120 fps
1920x1080 60 fps
1920x1080 30 fps
Bitrate
100 Mbps
Video Format
MPEG-4 (AVC/H.264, HEVC/H.265)
Still Resolution
4056x3040 (12 MP)
Still Formats
JPEG, DNG (RAW)
Still Modes
Single, Interval
Dynamic Range
13 stops
Storage
Removable Micro SD Card
UHS Speed Class 3 / V30
Stabilization Mechanical Range
pitch ±124°, roll ±120°, yaw ±12.5°
Pitch Controllable Range
-110° to +45°
Navigation Camera System
Configuration
6x cameras in trinocular configuration top
and bottom
Sensor Type
Sony 1/3” 4K color CMOS
Lens Aperture
f/1.8
Field-of-view
200°
Environment Coverage
True 360°
Framerate
30 FPS
Skydio Battery
General
Size
64.5 x 121.6 x 38.8 mm (l x w x h)
Type
lithium ion polymer
Configuration
3s1p
Energy Capacity
4280 mAh (48.79 Wh)
Nominal Voltage
11.4 V
Weight
280 g
Maximum Charging Voltage
13.05 V
-5°C to 40°C
Charging Temperature Range
0°C to 35°C
Skydio Beacon
General
Size
43 x 129 x 19.5 mm
Weight
91.5g
Battery Capacity
1460mAh 3.8V
Battery Life (active)
3 hr
USB Ports
USB-C (charge and data)
-5°C to 40°C
Control Options
Drag and drop positioning
Adjust tracking azimuth
Adjust tracking range
Adjust elevation
Initiate One Shot
Stop and hover
Wireless & GPS
Range (line of sight, ideal conditions)
1.5 km
2.4-2.483 GHz
5.18-5.24 GHz
5.725-5.85 GHz
20, 40, and 80 MHz
5 and 10 MHz
GPS and GLONASS
Controller
General
Size folded
94 x 153 x 71 mm (l x w x h)
Size unfolded
153 x 153 x 117 mm (l x w x h)
Weight
386 grams
-5°C to 40°C
Live Streaming Resolution
HD 720p
iOS and Android Supported Mobile Devices
iOS and Android screen size up to 6" and
tablets with optional adapter
Battery Life
2h30 (Android)
5h30 (iOS)
Battery Capacity
2500mAh 3.6V
USB Ports
USB-C (Charge and Data)
Design and Manufacturing
Parrot SA
Wireless & GPS
3.5 km
2.4-2.483 GHz
5.18-5.24 GHz
5.725-5.85 GHz
20, 40, and 80 MHz
5 and 10 MHz
GPS and GLONASS
Last edited by Pixelpeter; Oct 02, 2019 at 10:39 AM. Reason: adding specifications
Oct 01, 2019, 05:10 PM
Pixelpeter's Avatar
Introduction of the Skydio 2; it got quite a bit smaller (and cheaper) than its predecessor the R1:
https://www.youtube.com/watch?time_c...&v=imt2qZ7uw1s
Test footage:
Skydio 2 test footage 0826: complex drone shots made simple (0 min 40 sec)
Getting started with Skydio 2:
Getting Started with Skydio 2 (3 min 19 sec)
The Verge - Hands on with Skydio2:
The best autonomous drone just got better (5 min 29 sec)
Oct 01, 2019, 06:54 PM
It looks very impressive, I wonder how well it goes flying autonomously flying amongst trees and bushes whilst tracking mountain bikers?
Oct 01, 2019, 07:51 PM
Bog Flusher Platinum Grade
Mad_angler1's Avatar
Skydio 2 autonomous quadcopter
I was very lucky to be able to speak with Adam the CEO of Skydio tonight on the launch of the Skydio 2. It’s very interesting product indeed and I’m looking forward to taking a look at it as soon as it comes to the Uk/EU.
Some interesting info from the conversation are
US manufactured, that’s assembly’s but parts are sourced all over the world.
Plans for UK and EU in 2020 but they are looking to possibly accelerate that after today’s feedback.
Consumer model won’t fly at night, due to vision systems needing a minimum light level, enterprise model to have an override for this.
No NFZ in consumer or enterprise model
Uses Parrot Anafi RC but it’s not compatible with Anafi,, they are using their own wireless protocol and as such Skydio RC and Beacon not compatible with Anafi. It’s a hardware deal on Parrot supplying the Remote to Skydio only.
Early preorders should be in users hands end of by November, production on ramp up now.
Oct 01, 2019, 10:52 PM
I see lots of things to like about it.
Tracking and obstacle avoidance are the best.
4K at 60 fps is good.
Image quality looks very good.
Wide angle lens
Good dynamic range
Camera can look up 45 degrees with no props visible
Beacon GPS tracker available
Tracks up to 10 people
Great warranty
Good price
Things I would be concerned about:
Battery held underneath by magnets (would this affect compass?)
Front props facing down with no landing gear. Will require clear flat landing zone.
Oct 02, 2019, 01:13 PM
Motorbike is faster than the 4K quadcopter drone
Oct 02, 2019, 05:44 PM
Pixelpeter's Avatar
More Skydio 2 videos popping up on Youtube:
Meet the Skydio 2 (2 min 6 sec)
SKYDIO 2 Put To The Test, So Amazing It's Hard To Believe ! (15 min 1 sec)
Looking awesome
Oct 03, 2019, 07:16 AM
This just might be the quad I’ve been waiting for. Great quality video, my question is how does it have no fisheye from a 200 degree lens? This is the game changer.
Oct 03, 2019, 09:24 AM
The 200 degree cameras are the six navigation cameras. The one used for filming is not that wide (20mm equivalent.) They don't list field of view for it.
Oct 03, 2019, 10:22 AM
Originalas's Avatar
Comparison with the DJI. Wow!
SKYDIO 2 makes DJI Drones LOOK BAD! ft. DJI Mavic 2 Pro Comparison (1 min 48 sec)
Oct 03, 2019, 10:38 AM
Regards - Randy
BigFQQT's Avatar
Hand launch / land only?
Or did I miss something???
Oct 03, 2019, 11:36 AM
Originalas's Avatar
Probably would scratch 360 cameras on the bottom.
As it will need a special case or it will get scratched in the backpack too..
Just like those special covers for insta360 and similar cameras.
Oct 03, 2019, 11:56 AM
dragbikebam's Avatar
I wonder what the FAA will think about this, one of the rules for SUAS flying is that you can't operate a vehicle while also flying your SUAS LOL. I'm not trying to troll but really this is an honest concern for people filming themselves. You might say that only apply's to commercial but if you upload a video on You-Tube it becomes commercial at that point right?
Oct 03, 2019, 01:32 PM
Tweaker
RemE's Avatar
Technically with the beacon you wouldn't be operating the drone, it's following the beacon with no interaction from you. The spirit of that reg is to not have you be distracted with operating a TX while driving. Besides VegasRobbi, not that many would use this function often, but excellent to have!
I've tossed in my Pre-order, looks like fun.
Oct 03, 2019, 01:58 PM
Unless it's demonetized
News Skydio R1 is the Smartest Drone in the Sky Jason Cole Multirotor Drone Talk 62 Oct 03, 2019 10:20 AM
Discussion Skydio R1 - 13 Cameras autonomous drone - This is the future!! sevet Multirotor Drone Talk 18 Feb 18, 2018 06:14 PM
Discussion R2-D2 quad JDMstuff Scratchbuilt Multirotor Drones 0 Nov 29, 2015 03:38 AM
Discussion R2 Hobbies is open again !! kuya- Electric Sailplanes 15 Oct 19, 2015 01:57 AM
