This thread is privately moderated by kopterheld, who may elect to delete unwanted replies.
Aug 08, 2019, 03:52 AM
Mini-Review
Eachine Reddevil Review PID Betaflight 4.0.5
Eachine RedDevil 105mm 2-3S FPV Racing Drone with Crazybee F4 PRO, Caddx EOS2 camera, 5.8GHz 25~200mW Nano Video transmitter
Banggood Coupon: BGWKRED or Drones6
http://bit.ly/ReDevi
RedDevil is like Sailfly-X but with better Caddx EOS2 camera and powerful VTX 25-200mW. From the weight equal to 37 grams which guarantees a lot of fun.
Pro:
- VTX 25-200mW
- EOS2 camera
- F4 AIO board 2S-3S
- support all receiver
Cont:
- bad PID BF configuration
– camera canopy is wobble
– video antenna is too loose
My review video (EN subtitle):
Eachine Reddevil micro FPV Racer 3S
Eachine Reddevil micro FPV Racer 3S (6 min 27 sec)
Suitable batteries:
GNB 300mAh 3S 30C
Banggood - http://bit.ly/Gnb300mAh3S
Amazon - https://amzn.to/2xg3kOx
Happymodel 300mAh 3S 30C
Banggood - http://bit.ly/M7Hd300mAh
Amazon - https://amzn.to/2IQ4zdY
BETAFPV 300mAh 3S 45C - https://amzn.to/2ZkvZS7
GNB 300mAh 2S 45C - Amazon - https://amzn.to/2S6C26U
GNB 450MAH 2S 80C -
Banggood - http://bit.ly/GNB2S450mah
Amazon - https://amzn.to/2Wq1WU1
My fixes:
1. add two cable tie to the camera canopy to resolve the video vibrations
2. add a cable tie to the video antenna to protect it
3. use textile adhesive tape to protect the motor cable
4. cut out the battery foam , so that the foam no longer presses on the front connector
5. replace the EOS2 camera with a Runcam Nano 2 if you have a FPV goggles with 4:3 aspect ratio
6. install Beta 4.0.5 with my Betaflight DIFF and the PID setting from Albert Kim SailFly-X
Image 06 - original Reddevil without battery
Image 01 - original Reddevil with the 300mAh 30C 3S LiPo
Image 18 - Reddevil with the 4:3 Runcam Nano 2 1.8 lens and cable tie on the camera canopy
Image 7 - Reddevil with the 4:3 Runcam Nano 2 1.8 lens and textile adhesive tape to protect the motor cable
Image 17 - textile adhesive tape to protect the motor cable
Image 16 - Reddevil with the 4:3 Runcam Nano 2 1.8 lens and textile adhesive tape to protect the motor cable
Image 14 - cable tie on the antenna to protect it
Image 01 - Fix 4 - cut out the battery foam , so that the foam no longer presses on the front connector
Image 01 - Reddevil with all 5 fixes
Image 08 - Reddevil with all 5 fixes with 1.5g more weight
Image 15 - Reddevil 1102 8700KV motor
My configuration with FrSky Crazybee-F4 board. The PID's are from SailFly-X to fly 3S Lipo with Rate1 profile and for 2S Lipo with Rate 2 profile. PID's setting are from Albert Kim Betaflight 4.0 PID Tune for Sailfly-X
I have installed Betaflight 4.0.5 to the Reddevil with this changes:
# diff 2019-08-05
# Betaflight / CRAZYBEEF4FR (C4FR) 4.0.5 Aug 1 2019
batch start
name Reddevil
feature -TELEMETRY
feature LED_STRIP
beeper -SYSTEM_INIT
beeper -ON_USB
beeper -CRASH_FLIP
beacon RX_LOST
beacon RX_SET
serial 0 2048 115200 57600 0 115200
led 0 4,7::CO:2
led 1 5,7::CO:2
led 2 6,7::CO:2
led 3 7,7::CO:2
led 4 8,7::CO:2
aux 0 0 0 1675 2100 0 0
aux 1 1 1 900 1250 0 0
aux 2 2 1 1300 1700 0 0
aux 3 13 2 1700 2100 0 0
aux 4 35 2 1600 2100 0 0
aux 5 47 2 1300 1700 0 0
set gyro_lowpass2_type = BIQUAD
set gyro_lowpass2_hz = 0
set dyn_lpf_gyro_max_hz = 800
set acc_calibration = 9,-21,-206
set min_check = 1010
set max_check = 2000
set rx_spi_protocol = FRSKY_D
set dshot_idle_value = 400
set motor_pwm_protocol = DSHOT600
set vbat_max_cell_voltage = 460
set vbat_min_cell_voltage = 300
set vbat_warning_cell_voltage = 310
set vbat_scale = 111
set vbat_divider = 11
set beeper_dshot_beacon_tone = 5
set small_angle = 180
set deadband = 4
set yaw_deadband = 4
set pid_process_denom = 1
set osd_warn_esc_fail = OFF
set osd_vbat_pos = 2465
set osd_rssi_pos = 2081
set osd_tim_1_pos = 54
set osd_tim_2_pos = 2486
set osd_flymode_pos = 2456
set osd_g_force_pos = 65
set osd_throttle_pos = 2423
set osd_crosshairs_pos = 2253
set osd_current_pos = 2400
set osd_mah_drawn_pos = 2433
set osd_craft_name_pos = 2442
set osd_warnings_pos = 329
set osd_avg_cell_voltage_pos = 2497
set osd_disarmed_pos = 2410
profile 0
set dterm_lowpass2_type = BIQUAD
set dterm_lowpass2_hz = 150
set vbat_pid_gain = ON
set feedforward_transition = 30
set iterm_relax_type = GYRO
set iterm_relax_cutoff = 11
set p_pitch = 29
set i_pitch = 85
set d_pitch = 30
set f_pitch = 95
set p_roll = 24
set i_roll = 78
set d_roll = 26
set f_roll = 90
set p_yaw = 55
set i_yaw = 55
set d_yaw = 8
set f_yaw = 25
set angle_level_strength = 65
set horizon_level_strength = 65
set level_limit = 75
set d_min_boost_gain = 30
set d_min_advance = 0
rateprofile 1
set roll_rc_rate = 120
set pitch_rc_rate = 120
set yaw_rc_rate = 130
set roll_srate = 75
set pitch_srate = 75
set yaw_srate = 80
set tpa_rate = 80
set tpa_breakpoint = 1700
rateprofile 0
set roll_srate = 75
set yaw_srate = 80
set tpa_rate = 80
set throttle_limit_type = SCALE
set throttle_limit_percent = 75
batch end
More Coupons:
http://bit.ly/KhFaceBo
https://kopterheld.wordpress.com/2018/01/01/news/
Or Telegram App:
https://t.me/KopterHeld
My Equipment:
Fatshark Dominator HDO - http://bit.ly/BgFaHDO
ImmersionRC RapidFIRE - http://bit.ly/BgRapidFire
Eachine Pro58 Achilles - http://bit.ly/EaPro58
FrSky TARANIS Q X7 - http://bit.ly/2zLLvJq
FrSky X9D Plus SE - http://bit.ly/2z4KxXG
FrSky Taranis X-Lite - http://bit.ly/BgXlite
iRangeX IRX4 Plus Multi Modul - http://bit.ly/2QrTIeT
FrSky R-XSR - http://bit.ly/2S6rNyc
RunCam Split Mini 2 - http://bit.ly/2SKjCMQ
RunCam Racer 2 - http://bit.ly/2BZJCtq
RunCam Micro Eagle - http://bit.ly/2BPNnkL
Youtube – https://www.youtube.com/kopterheld
FaceBoo – http://bit.ly/KhFaceBo
Blog – https://kopterheld.tv/
RCGroups – https://goo.gl/JYP87D
Telegram - https://t.me/KopterHeld
Instagram - https://instagram.com/kopterheld
Twitter - https://twitter.com/kopterheld
Support me on your next purchase on Banggood or Gearbest
Banggood - http://bit.ly/khBanggood
Gearbest - http://bit.ly/khGearbest
Discussion Eachine reddevil (toothpick) review and (up to date ) useful info. nigelsheffield Micro Multirotor Drones 72 Aug 20, 2019 02:00 AM
Discussion Looking for reviewers of eachine RedDevil BG-Wilson Multirotor Drone Talk 32 Jul 08, 2019 12:15 PM
Discussion "Sticks On Switch" Betaflight 4.0 3" Quad PIDs TMacFPV Micro Multirotor Drones 2 May 04, 2019 11:06 AM
