Aug 06, 2019, 07:05 PM
Normal SERVO chatter?
Using an AR7210BX with spectrum H6050 and H6060 servos and while powered up they make a ton of noise. I don't really see any movement, but I can feel the vibrations. The rudder servo makes the most noise, probably 4 times louder than the others. Is that normal?
Also normal that the swash moves smoothly and comes back to center (although slowly) when stick released but rudder jumps to a spot and stays there on stick release?
Aug 07, 2019, 03:32 AM
Heligamist
BrokeDad's Avatar
The rudder servo won't start moving on it's own until the heli is spun up. As far as the servo noise a little is common but not a lot. Maybe you should check the frequencies you are running them all at in the AR7210. Also check for any binding.
Aug 07, 2019, 08:03 AM
My 480 servos are always making alot of noise. That gets replaced with fear after liftoff..
Aug 07, 2019, 05:55 PM
Thanks guys.
HH just put out a video on the 480 configuration and I heard the same racket coming from their servos so must just be the way they are. I would have thought full size metal gear digital servos would be quiet. My 230 s v2 don't make any noise and they are half the price.
Aug 08, 2019, 03:47 AM
Cyclone 7's Avatar
Having your Tx too close to the heli can result in servo chatter and also binding failures.
Oct 09, 2019, 10:32 AM
Turnigynarian
2Doggs's Avatar
RC Deadband
Sometimes it can help to increase the RC deadband setting in the controller.
Discussion New servo chatter Kirwin Radios 2 Jan 01, 2016 03:06 PM
PCM receiver servo chatter really normal? Brad B. Radios 27 Jan 16, 2006 04:19 PM
is servo chatter normal w/ Eclipse? Crewl1 Hitec/Multiplex USA 1 Mar 08, 2004 10:30 AM
Brushless motor "chattering" on startup normal? invicta High Performance 14 Sep 14, 2002 10:45 PM
Brushless motor "chattering" on startup normal? invicta Foamies (Kits) 4 Sep 09, 2002 06:59 AM
