This thread is privately moderated by Merch, who may elect to delete unwanted replies.
Aug 06, 2019, 11:18 AM
Merch's Avatar
Eachine E520S GPS 5G WIFI FPV 4K/1080P HD Camera Foldable RC Quadcopter
Eachine E520S GPS WIFI FPV With 4K/1080P HD Camera 16mins Flight Time Foldable RC Drone Quadcopter - 5G WiFi 1080P
Looks like someone stood on the box i can't get the compass or gyro to calibrate even with 14+ satellites,no flying for me.....Added some teardown pictures.
Description:
Brand Name: Eachine
Item NO.: E520S
Frequency: 2.4G
Channel: 4CH
G-yro: 6 axis
Motor: 8*23mm Brushed Coreless
Quadcopter Battery: 7.4V 1200mAh Lipo (Included)
Transmitter Battery: 4 x 1.5 AAA Battery (NOT Included)
Flying Time: 14-16mins
Charging Time: 120-150mins
R/C Distance: 200-300m
Flying Weight: 280g (with Battery)
Color: Black
Camera Optional: 720P / 2.4G WiFi 1080P / 5G WiFi 1080P / 2.4G WiFi 4K HD / 5G WiFi 4K HD
FOV: 120° Wide Angle
Pixel: 720P--Picture/Video: 1280*720
1080P--Picture: 1920*1088, Video: 1280*720 (Saved on Mobile Phone)
1080P--Picture: 1920*1088, Video: 1920*1080 (Saved on SD Card)
4K--Picture/Video: 3840*2160 (support IOS 6 or above and Android high-end system)
4K--Picture/Video: 2560*1440 (Saved on SD Card)
WiFi Distance: 2.4G WiFi: 50-70m
5G WiFi: 150-250m
Quad's Size: 40*28*7.5cm (the arms not folded, with props guard)
15*11*7.5cm (the arms folded)
Features:
- With foldable arm, small size, easy to carry.
- GPS positioning mode provides a more accurate flight.
- With 5G / 2.4G wifi function can be connected APP, APK system to take pictures/video, real-time transmission through the phone camera image
- 5G wifi fpv distance up to 250m.
- Optional 720P / 2.4G WiFi 1080P / 5G WiFi 1080P / 2.4G WiFi 4K HD / 5G WiFi 4K HD camera give wide range high denfinition pictures and video.
- Follow me: the aircraft will fix the controlling cellphone and follow the operator whichever direction he moves.
- With altitude hold mode function provides stable flight.
- Surround action will enable the aircraft flying in a circle, providing cooler shooting perspective.
- Waypoint flight mode, just draw a route on the screen, the copter as the give path.
- With 7.4V 1200mAh battery, the fly time up to 16 mins.
- With Headless Mode,no need to adjust the position of aircraft before flying .
- With One key to return function makes it easily to find the way home.
- One Key Takeoff /Landing. One press automatically taking off or landing, the drone will take off or go back to the position where it took off.
- With low power protection overcurrent protection.
- 2.4GHz Technology Adopted for Anti-Interference.
- 4 Channel which can do ascend, descend, forward, backward, left sideward fly, right sideward fly.
- 6-axis g-yro which can have more stable flying and be easy to control.
- It have 3-level flight speed to switch that can make more fun with the flying.
- The quadcopter fuselage is made of high strength and resistant engineering plastics,lightweight and durable resistance.
Function: Up/down, Forward/backward, Turn left/right, Sideward flight, 3-level flight speed, LED Light, GPS Positioning, Follow Me, Surrounding Flight, Waypoint Flight, Altitude Hold Mode, Headless Mode, One Key Return, One Key Takeoff /Landing, WiFi FPV, Camera/Video
Package Included:
1 x Eachine E520S RC Quadcopter
1 x Remote Control
1 x 7.4V 1200mAh Lipo Battery (Can be choose the battery quantity when place an order)
1 x USB Charging Cable
4 x Protection Cover
2 x Spare Blades
1 x Screwdriver
1 x User Manual
Aug 07, 2019, 09:31 PM
Merch's Avatar
Updated with some pictures,this is the 5G 1080P version.
Aug 07, 2019, 10:18 PM
(͡° ͜ʖ ͡°)(͡° ͜ʖ ͡°)(͡° ͜ʖ ͡°)
JohnCC's Avatar
Looking forward to the flight test. Interested in hearing generally if you think this one is worthy or not :3
Aug 08, 2019, 06:17 AM
kodak_jack's Avatar
Does it look as if those Phillip's head screws that are on the blade holders seem as if they'll last? I know video has to go to a phone, but are there other functions that have to go through the phone? Can it be flown without a smart phone? Can the video be stored to an SD card?
Aug 09, 2019, 07:44 PM
Hi
I considering purchasing one of these to learn and figure out.
Do you know what mega pixels the camera is? I'm expecting 2MP
Can the camera angle adjustable from the controller/phone app during flight?
The answers to them are not clear in the spec list.
Cheers
Matt
Aug 13, 2019, 01:20 PM
Merch's Avatar
Looks like there won't be a test flight as i cannot get the compass to calibrate even with 14+ satellites or the gyro,scratching my head on this one
Screws on the top will wear out in time,as i typed above i cannot get the compass to calibrate or the gyro after trying.........and giving up i did try to fly with transmitter only and that ended badley!!........can't comment on anything else atm as there seems to be a major problem with mine.........I will check to see if it saves to the SD card as i have seen 2 other vids where one cannot record to the SD card and another with a problem with the transmitter.
Maybe mine is defective as the box arrived like someone had stood on it.....worse than in the picture.
Originally Posted by Matt.Ludlow
Hi
Cheers
Matt
1080P is 2mp i will check and let you know,the camera angle can only be adjusted by hand.
Aug 14, 2019, 12:24 PM
That battery being 2S 1200 mah seems a bit hefty for brushed motors. Swap out the FC and powertrain with the EX2 mini and you’ve got a quality drone.
Aug 14, 2019, 05:03 PM
kodak_jack's Avatar
Brushed motors?
Aug 15, 2019, 01:32 PM
Merch's Avatar
Brushed motors?
Yes brushed motors.
Aug 19, 2019, 09:12 PM
Merch's Avatar
Since i have a lemon maybe best to check this thread for pictures and videos.
https://www.rcgroups.com/forums/show...eviewers/page2
Aug 20, 2019, 05:28 AM
kodak_jack's Avatar
Originally Posted by Merch
Yes brushed motors.
For brushed motors, they seem to be very compact. Have you run into motors like that before?
Aug 20, 2019, 12:51 PM
Merch's Avatar
Brushed motors attached to gears yes..........since i can't fly it i will do a teardown and see what's inside
Aug 20, 2019, 03:48 PM
Merch's Avatar
I must admit the quad is put together very well,easy to take apart just one screw hiding under the lip near the wifi module..........everything is plug and play so you can swap parts out easy,nothing that i can see is wrong with mine so i'm guessing there is a part that is defective.
The main motors are brushed attached to gears with metal shafts wich is better than plastic and bushings to hold the shaft in place well greased.
Maybe no flying for me but atleast there are some pictures of what is inside the quad.
Aug 21, 2019, 06:26 AM
kodak_jack's Avatar
I suppose for the money, it’s OK, but, a more expensive model with brushless set up and real bearing might be nice. Then again, you’re already into DJI Spark money.
Dec 10, 2019, 02:55 AM
Hello Merch,
Please, will it be possible for you to provide me the dimensions (Also pictures if possible) of the Flight controller mount seen in the image 44.
To give you idea what I am trying to achieve, I am trying to build E520S from spare parts. Unfortunately, the FC mount is not under spare parts for sale anywhere, actually there are 2 more things missing but i can live that (LED cover and power switch plastic cover). Once i have idea of the dimensions, I plan to 3D print it or at least do some workaround. Thanks in Advance
New Product MJX X103W 5G WIFI FPV With 1080P Camera GPS Follow Me Foldable RC Quadcopter RTF BGKevin Multirotor Drone Talk 12 May 24, 2019 01:37 AM
New Product JJRC H78G 5G WiFi FPV 1080P HD Camera GPS Foldable RC Quadcopter BGKevin Multirotor Drone Talk 7 Dec 27, 2018 05:38 AM
