This thread is privately moderated by GroundControlRC, who may elect to delete unwanted replies.
Aug 06, 2019, 08:20 AM
Video
Flight #14 - King Kong/LDARC Tiny Wing 450 FPV Test Flight!
Here is a link to the Video:
https://www.youtube.com/watch?v=NoIdOGNr6i0
This item is courtesy of Banggood.
I thought this Tiny Wing would make for an excellent Micro FPV Wing ;-)
It has several flight modes; 6-axis, 3-axis, and manual.
It's made from EPP Foam which should make it extremely durable ;-)
I installed a Micro FPV System and with the 2S 450mah 35C LIPO I use it puts the CG (Neutral Balance) right at the channel for the Servo Wires ;-)
I think that's very close to where it needs to be.
If I can ever get less than 5mph wind I'll be able to confirm that in Manual Mode.
This is the very first flight with an FPV System!
It's time to test out the FPV System!
The orange curve at the top and bottom right is a section of the canopy in view because I didn't get the camera positioned just right.
When to camera is positioned just right you not see any obstructions.
Get one today from Banggood!
Here is a link to the Micro AIO FPV Camera:
Turbowing 5.8G 48CH 25mw 700TVL 1/4 CMOS Wide Angle FPV Camera Support OSD NTSC/PAL Switchable
https://www.banggood.com/48CH-25mw-T...47791920140372
Here is a link to the SBEC (Switching Voltage Regulator):
Pololu 3.3V, 300mA Step-Down Voltage Regulator D24V3F3
https://www.pololu.com/product/2097
Here is a link to this Cool Micro Wing:
KINGKONG/LDARC TINY WING 450mm Wingspan EPP FPV PNP With Flight Control
https://www.banggood.com/KINGKONGLDA...47791920140372
Here is a link to the Micro SBUS DSM2/DSMX Receiver I used:
(Note: I changed the connector on the Flight Controller & Receiver to a Servo Connector)
MOY DS801 DSMX DSM2 Mini Compatible Receiver with SBUS PPM Output
https://www.banggood.com/MOY-DS801-D...47791920140372
Here are links to some LIPOs that should work as I could not find the LIPO I used:
(Note: This is based on the stated Spec/Dimensions/Weight of the LIPOs, I do not have these so I cannot confirm this is accurate)
Gaoneng GNB 7.4V 450mAh 2S 80C/160C Lipo Battery JST Plug
https://www.banggood.com/Gaoneng-GNB...47791920140372
URUAV 7.4V 450mAh 80/160C 2S Lipo Battery JST Plug for RC Drone
https://www.banggood.com/URUAV-7_4V-...47791920140372
KINGKONG/LDARC FLY EGG V2 100 RC FPV Racing Drone Spare Part 7.4V 450mAh 80C Lipo
https://www.banggood.com/KINGKONG-LD...47791920140372
See you in the Air!
