This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Aug 05, 2019, 07:37 PM
old4570's Avatar
FMS 800 V-tail
I have taken the FMS 800mm V-tail apart for some pictures .
A) There are a lot of similarities to the Ezio 800 , HK may have taken liberties . Especially as the prop is exactly the same .
B) Servo leads are SHORT !
C) 6A ESC
D) I think this model is intended as 2s around 350/450mAh
E) 2 servos take care of everything
F) V tail control rods were - WAY - Way - way out ( pre formed ) .. Not sure who was on the job that day - but I had to re do it , and it is tricky .
G) V tail is in 2 parts and needs gluing in place
H) Wing is held in place with a single screw . ( Philips head ) A hex screw would be better .
I) That prop !!!!! = Same as on the EZIO 800 , which was useless !
First thing I will do is check how much thrust the motor prop combo produces ( check current as well )
If thats ok , I will move onto soldering up a 4ch FS2A Rx .. and then assembling the FMS 800 V-tail trying for a decent CG ..
I have a small assortment of batteries to try ..
UPDATE
Current draw on a 2s = 4.7/4.8A to a peak of almost 5A
Thrust seems to be ok , looks like this motor might turn higher RPM on 2s
CG = No way ..
CG is sweet less Rx and battery ..
Will need weight in the tail or it will be nose heavy .
Just about to solder up a Rx now .
UPDATE 2
Rx is soldered and in place
Everything has been trimmed ready for CG Games ..
Seriously , the CG is perfect without a battery ...
Flying weight ATM with a Nonotech 370mAh 2s is 154 grams , but the CG is 25mm from the L/E
Power to weight . might be around 80%
There will be required weight in the tail for CG , which should probably be around 40 to 50mm from the L/E
Hmmm , what does the FMS manual say ? ( FMS say's 35mm from the L/E )
Discussion FMS 800m V-Tail Glider - Help changing spinner! monkeytron Parkflyers 1 Jul 08, 2017 08:08 AM
Mini-Review Eachine V-Tail QX110 - Redemption for the V-tail design? (review, work in progress) SoloProFan Micro Multirotor Drones 7 Apr 18, 2017 12:05 PM
Discussion To V-tail or not to V-tail . . . THAT is the question! muffcook Sailplane Talk 52 Nov 18, 2016 10:12 AM
Discussion V-tail vs inverted V-tail khaled_abobakr Ornithopters 15 Oct 04, 2016 03:50 PM
New FMS Blu-Beagle, bluecore v-tail trainer ggunners Simulators 14 Aug 18, 2005 07:29 PM
