Aug 06, 2019, 09:47 AM
Youtube channel : solentlifeuk
solentlife's Avatar
Holding it .... I think it would make a brilliant Slope Soarer ..... shame that Latvia has no good slopes !
The Soviets even had to 'build a hill' to create the Bobsleigh run in Sigulda !!
Aug 07, 2019, 05:32 AM
solentlife's Avatar
Nearly finished ... just wait paint to dry and then apply underwing decals and fuselage marks .... find a spare Rx and balance her ...
Quite pleased .. had a new 2826 2200kv spare ... so why not ??
Reckon she'll be good for 1800 - 2200 3S Lipo ...
Aug 11, 2019, 08:31 AM
solentlife's Avatar
Well she flies !! OK - had a bit of a 'do' to get her airborne and then motor mount sheered ... BUT SHE FLIES !!
Looks good in the air ...
Scratchbuilt profile Hawker Hunter maiden Cirava 10 Aug 2019 SS3 A (6 min 47 sec)
She's all repaired and ready for flight. I have tested with 4S and swapped the 6x4 prop for a 5x5 ... this gives me choice of 3S or 4S as I want ...
Aug 13, 2019, 04:49 AM
Clive Henry Jones's Avatar
Nice - I love the Hunter.
I always have a moan that people do not put the drop tanks under the wings - it seems most of the full size flew with them.
My next depron pusher will be a Eurofighter but I want to make it full fuselage. I have built the (KFm) wing and am now deciding on how to create the slightly awkward shaped fuselage.
Here's my last scratch built project, a depron KFm Vulcan.
Clive.
Aug 13, 2019, 05:12 AM
solentlife's Avatar
Clive.
Hop over the RCPowers web site ... they have used the score and fold technique to produce some amazing models ... virtually all their later designs are full fuselage but still hold to the flat plate wings etc.
https://www.rcpowers.com/categories
Well worth it ...
My Eurofighter is the TOMHE plan version (profile) and I love it. RCP - do a full fuse version ..
Aug 13, 2019, 05:22 AM
Hi Solentlife - will do, thanks.
Clive.
Yesterday, 01:51 PM
solentlife's Avatar
Flight with 4S / 5x5 on 2200kv .....
I think it exceeded the airframe as turns were difficult with anything more than about 60% throttle ... even then she would be slow to start and then tighten dramatically.
The elevators are highly tapered due to the shape of tail feathers ... making the outer section far larger ... this makes me think the elevators are flexing when first moved, then when airframe starts turn - they bang in ...
I slowed down into a turn but this and the gusty wind - she panned out into the tough grass ... broke of the nose and split rear fuselage.
A new nose section is easy to make from my templates and scarf in. Rear has already been repaired.
Cf spars into the elevators may help.
Swap out the 5x5 prop and revert to 3S but with 6x5 to give just a little more speed as maiden with 6x4 showed it needed just a touch more 'shove' !
By Glasses dvr ...
HHunter Ligas field 4S 17 Aug 2019 (3 min 45 sec)
Today, 04:08 AM
solentlife's Avatar
New nose section scarfed on and PU glue is curing ..
I cut back to create a joint that overlaps the wing to add some strength ... and also decided to extend the wing sheet to the nose creating a double thick laminated fuselage in vertical and horizontal section ... to carry the weight of that 2250 3S battery ...
The new sections were laminated with epoxy befoare scarfing into main body - the epoxy to provide a stiff glue line to assist with the foam resisting bending moments.
Final joints where gaps will be filled with PU / filler mix to foam up and seal.
Discussion Hawker Hunter- Century Jets BJH424 Fuel Jet Talk 37 Mar 05, 2018 07:05 PM
Discussion Hawker Hunter? kallend Foamy EDFs 4 Aug 17, 2016 09:07 AM
Build Log Flyfly Hawker Hunter totenkopf Electric Ducted Fan Jet Talk 20 Sep 17, 2015 03:24 PM
Discussion R/C Lander Hawker Hunter 6S - Shoreham Hunter crash. redtail Foamy EDFs 3 Aug 25, 2015 08:25 PM
Build Log 6mm Profile Hawker Hunter Binome Pusher Prop Jet Models 5 Jun 25, 2009 02:32 AM
