Aug 04, 2019, 02:07 PM
I did something... and it turned out woundefully
Hello fellow conqueres of the elements.
There is this 70 cm Edge clone thingy that slowly materialized in my living quarters.
Mostly 3 mm Depron
155 g without batterie
2280 kV motor 1806 size
6040 prop
12 A emax esc
2x 3.7g + 2x 4.3g servos (4.3 in the wing)
2s 260mAh at the moment
A bit of wood 3x6mm and too much hot glue
coated with simple sticky tape by 3M
The fuselage has no wood reinforcements whatsoever and the front has a little "design feature"
A plan for a canopy that houses the FPV camera was concieved, but i would rather fly all day.
I flew about 13 batteries so far and it is for sure the best plane I ever built.
Could use a bit more energy, for it needs a wee more than 3/4 stick to hover.
But it does everything I wanted and more.
It flies level at about quarter throttle and rolls like a champ.
Aug 09, 2019, 04:19 AM
Very nice indeed. Would love to see it fly.
What flight times do you get on the 260mAh?
Aug 09, 2019, 05:10 AM
Danish? Don't U eat that??
DKChris's Avatar
Nice idea trying with ordinary packing tape. Just did some coarse calculations on how much the tape ought to weigh, you know, sort of guesstimated from your picture, and I end up somewhere between 10 and 20 grams or btw. 1/3 and 2/3 of an oz. Thats actually not too shabby for a plane like this, which also shows in the AUW.
Aug 09, 2019, 08:14 AM
Did something similar on a plane built out of a combo of foamboard and balsa, with vynil tape.
The vynil tape can be shrunk afterwards with a heat gun.
Aug 09, 2019, 08:51 AM
DKChris's Avatar
So can ordinary polyester backed packing tape using a covering iron on low to medium setting; also locks in the adhesive......probably wouldn't go well with JustAHumans' airframe though
Only really tricky bit compared to actual covering material is that the tape tracks risk shrinking too much in width and pulling away from each other if you heat it too much.
Aug 10, 2019, 07:01 AM
Thanks. I would estimate about 6 min.
Update: I crashed it twice. And now I know where the weak spots are.
And because I broke the wing I made a new fuselage, of course... 44 g with motor and esc.
For the wing: I did something like this before, for my Focke Wulf Longnose. Just wanted to See with how little i could get away.
So I learned, that either the tape has to have contact with the profile-pieces, or you need reinforcements at the bottom or the top of the wing.
Aug 10, 2019, 07:03 AM
More pics.
Build Log Did not turn out as I had hoped. Where did I go wrong tom in tennessee Slope 371 Jun 23, 2017 07:04 PM
Discussion So how did the whole thing turn out? Sonny McGhee Life, The Universe, and Politics 35 Jul 06, 2016 12:06 PM
Discussion Did I figure something out Dirkdigla666 Mini Multirotor Drones 4 Mar 08, 2016 02:29 PM
Discussion Are DAL props just really bad or did I break something? boaterguy Mini Multirotor Drones 2 Jan 02, 2016 05:20 PM
I did something stoopid... and came out OK! Helicool Foamies (Kits) 5 Sep 19, 2003 10:46 PM
