This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Aug 21, 2019, 02:15 PM
Lithium Member
Herb's Avatar
I regularly check the availability of spare parts ... Most notably absent are the elevators :
https://hobbyking.com/en_us/catalogs...sult/?q=fresco
https://hobbyking.com/en_us/catalogs...bal%7C3&is_v=1
Aug 21, 2019, 06:58 PM
Lithium Member
Herb's Avatar
This is my latest FMS 90mm fan / inrunner setup, with a HK SK3 1900kv ($47 with disc code) motor - I have like three of those in the WeMoTec Evo 90mm fan and they are excellent motors for what they cost.
https://hobbyking.com/en_us/turnigy-...html?wrh_pdp=2
The rotor was statically balanced on a magnetic balancer and it was very very close, near perfect !
I will run it up on the bench to double check for vibrations once the ge silicone II cures ... It will go the MiG-17 to replace what looks like an inefficient $3 stock outrunner
Expect to pull roughly ~112A and ~2500 Watts based on my calculation.
Aug 22, 2019, 05:11 PM
Lithium Member
Herb's Avatar
The next step is the removal from the MiG-17 of the stock AF-Model outrunner fan.
It comes pre-balanced (see blue weight in spinner) so it's important - if taken apart - to mark with a pen the exact location of the spinner
Edit : A Google search reveals that the stock fan looks rather similar to the HSD Viper 90mm fan :
https://rcsa.org.za/product/v4-90mm-...6s-duct-motor/
which uses the exact same D3541 1550kv outrunner motor ... Nevertheless there are some differences.
Aug 22, 2019, 05:19 PM
Lithium Member
Herb's Avatar
Next is the FMS fan / SK3 inrunner install, some very minor foam shaving required ~4mm at the back (the FMS fan shroud is 4mm longer).
Fits like a glove
Also, a rotation direction check & an esc re-program for a 4-pole inrunner (6 degrees timing advance).
EDIT :
I measured this setup with a watt meter, and on a fully charged HRB 50C 5000 I get 124A and 2805W with the stock esc on low (6 deg) timing.
Might have to either fly mostly at half throttle or upgrade the ESC to a YEP 150A ...
Aug 25, 2019, 12:05 AM
Lithium Member
Herb's Avatar
Three more good flights today ... One of the easiest edf jets to land if you control the speed, comes down nice and stable
The FMS / inrunner fan provides a very significant power boost - which the MiG-17 can use ... Might try a WeMoTec evo next week.
On the last flight the right retract unit quit and would not go up past ~45 degrees, a bit frustrating ... ordered a replacement. One of the gear door servos plastic gears must have stripped as well.
Soo, gear doors are gone now
Aug 25, 2019, 01:29 PM
Lithium Member
Herb's Avatar
Originally Posted by Herb
... On the last flight the right retract unit quit and would not go up past ~45 degrees, a bit frustrating ... ordered a replacement.
It turns out it was just dust ... these units have tight tolerances and seem very sensitive to the smallest grains of sand or dust slowing down the screw mechanism.
Took out and cleaned both units with compressed air and later wd-40, and now they seem to work fine ... till the next jam
Aug 25, 2019, 01:36 PM
Lithium Member
Herb's Avatar
Going to try next the WeMoTec Evo fan with HK SK3 1900kv inruner ...
80mm diam outlet too big for most 90mm edf fans.
Aug 25, 2019, 04:11 PM
Herb - thank you for posting these detailed pictures!
Info please regarding one picture - it shows 4.8 V batt.
Is this the operating voltage for retracts (did you measure the voltage on original unit), or just allows you to test, albeit with less deployment speed ?
Thanks in advance, Darko.
Aug 25, 2019, 04:37 PM
Lithium Member
Herb's Avatar
I think the retracts can take higher voltage (BEC's nowadays are 5.5 to 6.0V) but the 4.8V nicad was for testing purposes only.
The MiG-17 kit has a separate retract actuator box, which cuts off the voltage to the retract unit (any one of the three) if a certain amp load is exceeded...
Aug 25, 2019, 05:06 PM
Thank you!
Aug 25, 2019, 11:41 PM
Lithium Member
Herb's Avatar
Six flights today now with the WeMoTec Evo / inrunner setup.
Flies just as well as with the FMS 90 fan / inrunner setup of yesterday if not better, but picked up some extra speed in spite of the added steel grille ...
It seems the WeMoTec setup is a bit more efficient (at least in this airframe) than the FMS inrunner setup.
Next have to clean up the intakes a bit, there's still a lot of junk (servo wires, rods and blunt edges) hanging in there.
After sucking in a small stone, I put a steel mesh over the intake. But unless you have lots of stones & such on your runway, you can be better off without one. That's why it's always a good idea for it to be removable, & the process to be reversible.
All my stainless steel meshes are from $3 walmart 6" mainstay strainers,
https://www.walmart.com/ip/Winco-MS3...lspartner=wlpa
Aug 26, 2019, 12:00 AM
Lithium Member
Herb's Avatar
Today's visitor at the field
Wile E. Coyote Wondering around the Flying Field (0 min 26 sec)
Aug 26, 2019, 04:14 AM
Going to try next the WeMoTec Evo fan with HK SK3 1900kv inruner,
Hi Herb!
Also have an WeMoTec Midi-Fan EVO 90mm (acquired previously for planed 3D print project) - can you please tell me how many amps your setup is pulling - what ESC you will recommend?
Any info on settings is also very appreciated.
Interested only in general terms - Avios MiG is my first EDF and for sure will not experiment with that for now - many things to lean before ..
Aug 26, 2019, 10:41 AM
Lithium Member
Herb's Avatar
Yesterday I've flown the MiG-17 with the WeMoTec Evo fan / HK SK3 1900kv inrunner motor on 6S using still the ESC that comes with the MiG !
The above WeMoTec setup pulls ca ~105A and ~2200W :
Aug 26, 2019, 10:45 AM
Thank you again!
New Product Avios 90mm 1200mm MiG-17 Fresco The Snake Foamy EDFs 2624 Yesterday 09:50 PM
News Avios MiG-17 Fresco Jet Fighter 90mm EDF 1200mm Jason Cole Electric Ducted Fan Jet Talk 12 Aug 08, 2019 07:00 PM
Discussion FMS Mig-17 90mm EDF Jet T-CAT Foamy EDFs 18 Oct 19, 2016 10:46 AM
Discussion 'Stick and tissue' Mig 17 Fresco for 30mm EDF JetPlaneFlyer Micro EDF Jets and Power Systems 80 Jan 28, 2015 01:40 PM
