This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Aug 02, 2019, 12:28 PM
Lithium Member
Herb's Avatar
Build Log
MiG-17 Fresco 90mm EDF by Avios / HK / AF-Model
The new MiG-17 edf is made I think by AF-Model, and distributed by Hobbyking under the Avios brand,
https://hobbyking.com/en_us/avios-mi...m-edf-pnf.html
It is also available as a kit, which does not include retracts or sevos :
https://hobbyking.com/en_us/avios-mi...f-arf-kit.html
A whole bunch of spare parts are listed here :
https://hobbyking.com/en_us/catalogs...iG-17%20fresco
Some interesting features of this one are the custom retracts (with custom controller) and the use of (presumably more reliable) 11 x 9g analog servos.
The MiG-17 is made by AF-Model ("Air Fly Limited") : www.af-model.com
The full-scale MiG-17 has a wingspan of 9.63m and a length of 11.26m :
https://en.wikipedia.org/wiki/Mikoyan-Gurevich_MiG-17
whereas the model has a wingspan of 120cm and a length of 142cm, which gives an approximate scale of ~ 1:8.0 .
Edit : Videos added from & after the maiden Sat. Aug 17 2109
MiG-17 Avios Evening Flight - 4K UHD (3 min 36 sec)
MiG-17 Fresco by Avios - WeMoTec Evo 90mm fan (3 min 15 sec)
MiG-17 Avios Dusk Sortie - 4K UHD (3 min 53 sec)
MiG-17 Fresco 90mm EDF by Avios - Four Easy Landings (1 min 52 sec)
Aug 02, 2019, 12:31 PM
Lithium Member
Herb's Avatar
With various coupons and discounts it is possible to drive the price down a bit, and it often includes free shipping from the US warehouse,
Aug 02, 2019, 12:35 PM
Lithium Member
Herb's Avatar
The MiG-17 comes with a 90mm plastic fan with an outrunner motor (claimed to be a 3541 1550kv), which I will replace.
It is claimed that the stock setup on 6S pulls ~ 80A x 22V or ~ 1800W ... The stock esc is rated at 100A.
Most likely I will first try a WeMoTec 90mm MidiFan evo, or an FMS 90mm fan with a quality inrunner motor,
Aug 02, 2019, 12:46 PM
Lithium Member
Herb's Avatar
I once had a MiG-17 fiberglass 75mm EDF, made by EAM. It flew pretty well until the elevator servo mount detached ...
That is when I found out that epoxy resin does not stick to polyester, here specifically a polyester fuselage.
Aug 02, 2019, 01:00 PM
Lithium Member
Herb's Avatar
I don't particularly like that white/gray/black camo it's painted in, so I will re-surface and re-paint mine, most likely in a russian (soviet) scheme
Aug 03, 2019, 11:29 AM
rockiesguy's Avatar
Hi; I'm planning on buying the plane too and also change the color scheme to a more classic one...since I want to put a turbine in it I have to go fuel-resistant paint brand.. it would be nice to see the process you do.
Aug 04, 2019, 11:23 AM
Lithium Member
Herb's Avatar
If you plan to install a small turbine in yours then Henke is your man
The turbine is placed all the way at the end of the fuselage, to avoid melting the foam ... whether that causes CG issues will be interesting to find out ... teh fuel tank has to be located close to the CG.
I believe Henke is installing a Kolibri turbine in his.
Aug 04, 2019, 11:27 AM
Lithium Member
Herb's Avatar
The MiG-17 offers a number of interesting options when it comes to repaint :
Soviet air force, Polish, Chek, North Vietnam, Cambodia, Cuba, China, Syria, Egypt, DDR etc. and of course current US ownership ...
Aug 04, 2019, 11:35 AM
Lithium Member
Herb's Avatar
Plastic models often offer very fine details on various items such as cockpit, landing gear etc.
Aug 05, 2019, 05:34 PM
Lithium Member
Herb's Avatar
Elevator and Rudder details,
EDIT : Note that on mine the rod connecting upper and lower rudders was not glued in properly / loose. That causes the upper rudder to get out of alignment with respect to the lower one, and could cause trim problems.
Aug 05, 2019, 05:38 PM
Lithium Member
Herb's Avatar
Assorted hardware & small parts,
Aug 05, 2019, 05:43 PM
Lithium Member
Herb's Avatar
Plastic fan, outrunner motor, 100A esc and intake details,
Aug 05, 2019, 05:46 PM
Lithium Member
Herb's Avatar
Electronics include a retract activating unit, a gear door sequencer and a switch box with led lights output,
New Product Avios 90mm 1200mm MiG-17 Fresco The Snake Foamy EDFs 3410 Feb 16, 2020 01:15 PM
News Avios MiG-17 Fresco Jet Fighter 90mm EDF 1200mm Jason Cole Electric Ducted Fan Jet Talk 12 Aug 08, 2019 07:00 PM
Discussion FMS Mig-17 90mm EDF Jet T-CAT Foamy EDFs 18 Oct 19, 2016 10:46 AM
Discussion 'Stick and tissue' Mig 17 Fresco for 30mm EDF Smoggie Micro EDF Jets and Power Systems 80 Jan 28, 2015 01:40 PM
