Aug 01, 2019, 10:44 AM
What carb will work in a SuperTigre .27?
I have Aquacraft's nitro Alligator Tours airboat and it's missing the carburetor. It is the SuperTigre .27 ST engine, and the carb should be the 300 Rotary (see photo). It seems to be gone everywhere so I need a replacement carb. Any ideas? If anyone has one I'd like to buy.
Aug 05, 2019, 12:43 PM
Any clue, anyone?
Aug 06, 2019, 07:09 PM
Nitro77
what is the ID of the carb mount? I would contact K&B and see if they one that can be matched for your engine.
http://www.mecoa.com/kb/89/89-parts.htm
a 3.5cc engine carb for example.
K&B Carburetor (Gold) 94 (.312 inlet) Darker Gold, No Idle adjustment screw, uses snap ring to hold barrel (Neck dia .437)
K&B Carburetor (Red) (.345 inlet) (Neck dia .437)
Aug 06, 2019, 09:33 PM
It is 14 mm
Aug 07, 2019, 08:16 AM
glgirvin's Avatar
Hi beedleman, On my OPS .21 size engines, I preferred to use OS carberators. I like them because they shut down both and fuel when slowing down as to not flood out the engine. I used either a 2D or 3D size depending on bore size wanted. Some times I had to turn down neck to fit engine. I would not rely only on the cross or set screws to hold ther carb in. I would use 5 minute epoxy on the neck and snug the cross bolt until epoxy cured. I would only have to loosen cross bolt and twist carb to remove. I never had any carbs come loose during operation. Thank you, Gary
Discussion Vx.18 what has changed what will still work ChristopherD76 Nitro and Glow Power Cars 2 Dec 02, 2016 08:39 AM
Discussion What dvr or dvr/monitor combo will work with.... marcusg FPV Talk 3 Oct 14, 2015 11:35 PM
Discussion What fpv monitor will work with the Nano qx fpv ? marcusg Mini Multirotor Drones 4 Oct 13, 2015 01:12 AM
Discussion What other quads will work with my Spektrum tx? ryan93civic Beginner Multirotor Drones 0 Sep 13, 2015 02:00 AM
Carb Batery Charger As 12v DC Power Supply???? Will This Setup Work putt_13 Electric Plane Talk 2 Aug 13, 2002 12:13 PM
