This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Jul 31, 2019, 09:34 PM
old4570's Avatar
Custom Battery for the EZIO 800
Yes , it is time for a dedicated Ezio 800 battery .
Some may know already that the Ezio 800 is battery challenged . ( Most batteries wont fit and those that do wont give you CG )
I ordered some batteries from HK ..
Took the plastic caps off ( Care needed as the tabs are fragile - hence the plastic cap )
Re solder the negative wire to the negative terminal on the second battery ..
Connect the negative and positive terminals on the two batteries so as to connect the batteries in series . ( 2s - 8.4v fully charged )
Glue , tape the cells together .. I needed weight so taped them .
Then I used hot glue to seal the terminals ( they be fragile ) , the hot glue should releave all stress and give the terminals strength .
Nov 20, 2020, 12:24 PM
pull up -- PULL UP!!!
Don't know if you're still flying this plane, but here's the battery that works for me:
GNB 450mAh HV 7.6v 2S 80C - HV Lipo XT30 Battery
https://newbeedrone.com/products/gnb...smart_campaign
Different connector, but that was what I wanted. I use this same excellent battery on a half-dozen planes. Fits EZIO 800 easily.
