Jul 31, 2019, 02:46 AM
Droner730's Avatar
New Product
Etlas Mobile GCS: Android 7.1 OS / Quad-core Processor/Handheld/ Highly Integrated
INTRO
For any longtime outdoor individual operation in harsh environmental conditions, controlling your drones could be very difficult and time-consuming especially when you encounter intense sunlight and sudden rain. What you care more is that you wish you could take as less devices as possible with you so you could finish the task efficiently. However, there is a great option available now to change it all. Today I want to share a handheld GCS from MMC UAV——Etlas Mobile.
Etlas mobile is a new generation of industrial handheld ground station system that combines functions of remote, computer, image transmission, antenna and monitor, and features integrated, compact and lightweight design.
Description:
SPECIFICATIONS
Size (L*W*H)- 320x142x54mm
Weight- 1.2kg
Operating System- Android 7.1, Six-Core Processor
Screen- 7-Inch Touch Screen
Battery- 11.1V,8000mAh
Video Output- HDMI
Transmission Distance- 5km
Working Temperature- -20℃~55℃
Resoultion- 1920*1200
Max Brightness- 1200nit
Touch Screen- Max. 5-point Simultaneous Touch
Connector- USB,HDMI,MICRO SD,MICRO SIM,UART
Battery Life- 5 Hours
HIGHLIGHTS
1. High Integration
Etlas mobile covers functions of real-time control, route planning, image display and payload control. With two frames in on screen, users can capture all information in one glance. It combines functions of remote, computer, image transmission, antenna and monitor, sparing the effort of matching different devices.
Description:
2. Image and Data Transmission in One
Etlas mobile integrates high resolution image link, data control station and remote control link for bidirectional transmission. It supports SBUS, HDMI and other connectors, allowing for real-time bidirectional data transmission. Image-data integrated transmission spares the problem of frequency interference and incompatibility and simplifies the works of system installation as well as debugging.
Description:
3. Touch Control to Switch Frames
Users can simply touch the screen to switch between the ground station frame and UAV frame according to monitoring priority.
Description:
4. Highly Bright Screen
The brightness of Etlas Mobile screen can reach 1200 nit, which makes it still clearly readable under the greatest sunlight exposure.
Name: 5 屏幕:超高亮显示.jpg
Description:
5. IP 52 Ingress Protection
Wrapped by silicone cell and sealed with 3M glue,Etlas mobile is of IP52 level, resistant to dust and water and shock-absorbing.
Description: Dust-proof
Description: Rain-proof
6. Five-finger Simultaneous Touch Control
Etlas mobile is equipped with ultra-sensitive screen that allows for five-finger touch control and avoids interference caused by accident touch. It is therefore able to work under complex environment with great stability and reliability.
Description:
Jul 31, 2019, 02:52 AM
Droner730's Avatar
7. 5km Control Distance
Etlas mobile is equipped with a new generation of image transmission that could conduct real-time control from 5 km away, which is applicable to long-distance operation.
Name: 9 五公里通讯半径_英文.jpg
Description:
8. 5-Hour Battery Life
Equipped with high-performance battery system, Etlas mobile can last working for 5 hours to satisfy long-time outdoor operation.
Name: 10 5小时超长续航_英文.jpg
Description:
9. Adaptable to Extreme Temperature Environment
Etlas Mobile can satisfy the need for extreme temperature environment operation, with its adaptable temperature range from -20℃ to 55℃.
Description:
10. Compact and Lightweight
Etlas mobile measures only 32014254 mm and weighs only 1.2 kg, which makes it quite portable and convenient for emergent outdoor flying operations.
Name: 11 1.5KG重,便携性强.jpg
Description:
11. Strong Compatibility for Extensive Applications
Etlas mobile has multiple data connector ports which are adaptable with multi-rotor drones, fixed-wing drones, robots, industrial controller and monitoring gimbal, etc.
Name: 12 兼容性强_英文.jpg
Description:
12. Super Processing Power
Etlas mobile adopts high-performance six-core with Android 7.1 operating system. It features super strong processing power and high system stability to ensure long-time stable ground station work.
Name: 13 安卓7.1.jpg
Description:
Name: 14 六核处理器.jpg
Description:
Aug 01, 2019, 01:25 AM
Droner730's Avatar
Attachment 12366269
Attachment 12366271
Attachment 12366281
Attachment 12366273
Attachment 12366275
Attachment 12366277
Attachment 12366279
More pictures of Etlas
Description: Name: IMG_0993.jpg
Description: Name: IMG_0995.jpg
Description: Name: IMG_1001.jpg
Description:
Description:
Aug 01, 2019, 02:06 AM
Droner730's Avatar
Etlas Mobile Dust-proof Test Video
Etlas Mobile Dust-proof test (2 min 40 sec)
Aug 01, 2019, 02:13 AM
Droner730's Avatar
More pictures
Description: Name: IMG_0984.jpg
Description: Name: IMG_1056.jpg
Description:
Aug 01, 2019, 02:17 AM
Droner730's Avatar
Etlas Mobile Water-proof Test
小霸王 防雨 (1 min 10 sec)
Aug 01, 2019, 09:07 PM
Rubyra's Avatar
It's very convenient for those of us who are mapping in the field! And will be following as my startup company could use something like this to help cut down on the amount of gear necessary to tote to the field.
However, I would like to know how to control the flight path of the drone in a windy environment, because the place where I work is always windy.
Aug 01, 2019, 10:33 PM
Droner730's Avatar
Hi, I think it depends on the quality of your drones. What Etlas Mobile can provide is auto route planning for your operation.
Aug 02, 2019, 10:11 PM
Rubyra's Avatar
It is a handheld GCS with 5-hour battery life, does it mean I need to hold it all the time if my operations time is very long?
Aug 04, 2019, 08:29 PM
Droner730's Avatar
Hi, you don't have to hold it for that long, they have especially designed loops on both sides of the GCS into which a strap can be inserted for you to hold it around your neck.
Aug 06, 2019, 09:44 PM
Great to see a new ground control system,I am wondering if it could really reach 8-km distance?
Aug 08, 2019, 05:14 AM
Could it ?
Aug 08, 2019, 05:18 AM
Droner730's Avatar
Could it ?
Apology for my late reply. Yes, Etlas Mobile has been tested as being able to reach 8-km transmission distance on the condition of zero disturbance.
Aug 08, 2019, 08:47 PM
Rubyra's Avatar
OK, seems like the strap is relieving some pressure. Another questions is what kinds of drones can this apply to, do I must use MMC drones?
Aug 09, 2019, 10:07 PM
Droner730's Avatar
It can apply to drones using PX4 or APM firmware. Besides, as long as the drone has sbus connector and is through serial communication. Even for closed software, we can provide sdk so you can adapt this to your drones.
Discussion Android GCS for dji WKM and NAZA bjornthans Multirotor Drone Talk 8 Feb 26, 2014 12:55 PM
