This thread is privately moderated by Merch, who may elect to delete unwanted replies.
Jul 30, 2019, 10:55 PM
Merch's Avatar
Mini-Review
Happymodel Larva X 100mm Crazybee F4 PRO 2-3S 2.5 Inch FPV Racing Drone BNF
Spare parts http://bit.ly/2ktPndg
Happymodel Larva X 100mm Crazybee F4 PRO 2-3S 2.5 Inch FPV Racing Drone BNF w/ Runcam Nano2 Camera
Specification:
Brand Name: Happymodel
Model: Larva X
Item Name: 100mm 2-3S 2.5 Inch FPV Racing Drone
Wheelbase: 100mm
Size: 88x88x45mm (without propellers)
Weight: 50g (without battery)
Drone Version: BNF ( With Receiver & Without Battery)
Happymodel EX1103 7000KV Motor
Mode: EX1103
KV options: KV7000
Configu-ration:9N12P
Stator Diamter:11mm
Stator Length:3mm
Shaft Diameter: Φ1.5mm
Motor Dimension(Dia.*Len):Φ13.5x16mm
Weight:3.7g
Crazybee F4 Pro V3 Flight Controller
(Frsky version) CRAZYBEE F4FR PRO V3.0 Firmware target: CrazybeeF4FR
(Flysky version) CRAZYBEE F4FS PRO V3.0 Firmware target: CrazybeeF4FS
(No RX version) CRAZYBEE F4 PRO V3.0 Firmware target: CrazybeeF4DX
MCU: STM32F411CEU6 (100MHZ, 512K FLASH)
Sensor: MPU-6000 (SPI connection)
Board Size: 28.5x 28.5mm
Power Supply: 2-4S battery input (DC 7-17V)
Built-in 10A (each) Blheli_S 4in1 ESC Dshot600 ready
Frsky version Built-in SPI Frsky receiver with telemetry(D8/D16 switchable)
Flysky version Built-in SPI Flysky receiver with telemetry(AFHDS/AFHDS2A switchable)
No RX version need to add external Receiver
Built-in Betaflight OSD(SPI Control)
Built-in Current meter Max 70A
Current meter scale set to 470
Built-in 5V 1A BEC
Built-in voltage detection
Onboard 10A 4in1 ESC
MCU upgraded to EFM8BB21
Power supply: 2-4S LiPo/LiPo HV (7v/17v)
Con. Current: 10A
Burst Current: 12A (5S)
Support BLHeliSuite programmable
Factory firmware: F_H_40_REV16_5.HEX
Default protocol: DSHOT600
Onboard Frsky D8 Receiver Version
( Internal Frsky NON-EU receiver Version)
SPI BUS receiver
Frsky D8/D16 switchable
Compatible Non EU transmitter both D8 and D16 mode
Channels: 8ch or 16ch
Failsafe support
No ground interference ( Transmitter and receiver 1 m from the ground): 300m
Internal Flysky Receiver Version SPI BUS receiver
Protocol: AFHDS and AFHDS-2A Switchable
Channels: 8ch(AFHDS) or 14ch(AFHDS-2A)
Failsafe support
External TBS Crossfire Receiver version CRSF Protocol , Official TBS transmitter compatible
External DSMX Receiver version
Frequency range: 2.403-2.479Ghz
Input power: 3.3V -- 5V
Response time: 22ms / 11ms
Resolution: 1024/2048
Display method: LED
Operating voltage: 3.3V
Working current: 60MA
Weight: 0.9 g
Antenna length: 30mm
Data format: Serial port
Protocol: DSM2/DSMX
Distance: no ground interference (1 m from the ground ) more than 300m
External Frsky RXSR Receiver version
Weight: 1.5g
Number of channels: 16CH (1-16CH from SBUS channel, 1~8CH from CPPM channel)
Operating Voltage Range: 3.5V~10V
Operating Current:[email protected]
Firmware Upgradable
Compatibility: FrSky X Series modules and radios in D16 mode
Could support Frsky New ACCST Protocol ( Upgrade firmware)
Happymodel Diamond_VTX
Output power: 25~200mw switchable
Frequency: 40CH
Input voltage: 3.3V 5.5V
Current consumption: 250mA~510mA(type)
Antenna: RG178 antenna
U.FL interface
Frequency: 5.8GHz 5bands 40 channels
With Raceband
Smartaudio ready
Weight: 3g without antenna
Video Output Size: VGA (640x480)
Video Output format: NTSC
Record video size : 1280x720 @25FPS
TF Card support: Max.32G
Interface: JST SH1.0 3pin for Camera
JST SH1.0 5pin for Connect with F3/F4 Flight controller
Compress Format: AVI
Runcam NANO2 FPV Camera
Model: Nano 2
Image Sensor: 1/3" CMOS
Horizontal Resolution: 700TVL
Lens: 2.1mm(M8) FOV 155
Signal System: NTSC / PAL
S/N Ratio: >50dB
Electronic Shutter Speed: Auto
Auto Gain Control (AGC): Auto
Min. Illumination: [email protected]
D-WDR: Auto
Day/Night: Color
Power: DC 3-5.5V
Current : [email protected] [email protected]
Housing Material: ABS
Net Weight: 3.2g
Dimensions: 14x14x16mm ( LxWxH)
Recommend Lipo Battery
( All Version Don't Include) Recommend 2S 450mAh Lipo / 3S 300mAh/350mAh Lipo Battery
Features:
- New Crazybee F4 PRO V3.0 AIO Flight controller 2-4s Lipo Compatible
- Powerful and smoothly
- Betaflight OSD support ,easy to get RSSI, Voltage ,current from your goggles
- Camera Angle adjustable
- VTX power switchable 25mw~200mw
- Smartaudio ready , change VTX bands, powers, channels via OSD
- Receiver option: Frsky D8/ Flysky / DSMX / Frsky RXSR/ TBS CRSF
- Diamond VTX Ready
- Compatible both for 2-3S Lipo/LIHV
Package Included:
1X Larva X frame
1X Option1: Crazybee F4FR V3.0 PRO FC built-in Frsky NON-EU RX
Option2: Crazybee F4FS V3.0 PRO FC built-in Flysky RX
Option3: Crazybee F4FS V3.0 PRO FC with DSM2/DSMX RX
Option4: Crazybee F4 V3.0 with external Frsky RXSR receiver
Option5: Crazybee F4 V3.0 with external TBS Crossfire Nano RX
4X 1103 KV7000 motor
4X Micro Avan Rush Propeller 2.5 Inch ( 4 CW & 4 CCW)
1X Runcam Nano2 Camera
1X 5.8G 25-200mW VTX
1X Propeller disassemble tool
1X Screwdriver
Aug 28, 2019, 12:47 PM
Merch's Avatar
Should not be long now untill i receive one.
Aug 28, 2019, 11:04 PM
Merch's Avatar
Mine has been shipped
Sep 10, 2019, 04:22 PM
Merch's Avatar
Updated with some pictures.
Sep 12, 2019, 05:19 AM
Merch's Avatar
Happymodel Larva X Info Before First Flight And Test On 2S Lipo (9 min 43 sec)
Sep 15, 2019, 01:49 AM
Merch's Avatar
Larva X Another Great New Spot To Fly! (3 min 29 sec)
Sep 19, 2019, 08:47 PM
"Aircraftus Fragmentum"
kydawg1's Avatar
I finally had a chance to maiden today... digging this one.
2019 #108 Maiden HappyModel LARVA X 3S Rips 2019 0919 (Iron Maiden - 2 Minutes To Midnight) (6 min 5 sec)
Sep 20, 2019, 11:45 AM
Merch's Avatar
https://www.youtube.com/watch?v=tO5qCc6tyu0
Great flight.....will be a nice sunny day here tomorrow so i will have more footage in and my review done by monday i hope.
Sep 21, 2019, 07:12 AM
kydawg1's Avatar
Larva X DVR Preview - not yet public.
Updated Video LINK
2019 #112 HappyModel LARVA X DVR (Bruce Dickenson - Tears Of The Dragon) (6 min 8 sec)
Nov 27, 2019, 09:05 AM
Merch's Avatar
Happymodel Larva X HD 125mm F4 2-3S Toothpick HD Whoop HD 2in1 FPV Racing Drone BNF
A new Larva x hd 125mm coming out soon looks nice
Link HERE
Happymodel Larva X HD 125mm F4 2-3S Toothpick HD Whoop HD 2in1 FPV Racing Drone PNP BNF
Specification:
Model: Larva X HD
Item Name: Larva X HD 125mm F4 2-3S Toothpick HD Whoop HD 2in1 FPV Racer
Wheelbase: 125mm
Size: 105x105x35mm (without propellers)
Weight: Toothpick style ductless 63g (without battery)
Whoop style ducted 79g (without battery)
EX1203 6200KV Motor Configuration: 9N12P
Stator Diamter: 12mm
Stator Length:3mm
Motor Dimension(Dia.*Len): Φ15x5mm
Weight: 4.7g
No.of Cells: 2-3S Lipo
Crazybee F4FR PRO Flight Controller
Frsky SPI RX version: CRAZYBEE F4FR PRO V3.0 Firmware target: CrazybeeF4FR
Flysky SPI RX version: CRAZYBEE F4FS PRO V3.0 Firmware target: CrazybeeF4FS
External RX version: CRAZYBEE F4 PRO V3.0 Firmware target: CrazybeeF4DX
Sensor: MPU-6000(SPI connection)
Power supply: 2-4S battery input (DC 7-17V)
Built-in 10A(each) Blheli_S 4in1 ESC Dshot600 ready
Could add external receiver on the FC board
Built-in 5V 1A BEC
Onboard 12A 4in1 ESC
Current: 10A continuous peak 12A (5 seconds)
Factory firmware: F_H_40_REV16_7.HEX
Frsky SPI D8 Receiver Version SPI BUS receiver Frsky D8 compatible
Compatible Non EU transmitter D8 model
Channels: 8ch
Failsafe support
No ground interference ( Transmitter and receiver 1 m from the ground): 100m~200m
Flysky SPI Receiver Version SPI BUS receiver
No ground interference ( Transmitter and receiver 1 m from the ground): 100~200m
Failsafe support
External DSMX/DSM2 Receiver Version
Protocol: DSM2/DSMX
External Frsky XM+ Receiver Version
Number of Channels: Up to 16CH from SBUS (1-15ch for PWM,16ch RSSI for FC)
Operating Voltage Range: 3.7~10V
Operating Range: Full range
With RSSI output on board: Analog 0~3.3V
Antenna: 10cm
Firmware Upgradeable
Compatibility: FrSky D16 mode
External Frsky RXSR Receiver Version
Weight: 1.5g
Firmware Upgradable
External TBS CRSF Nano Receiver Version Original TBS CROSSFIRE Receiver , CRSF Protocol , Official TBS transmitter compatible
5.8G 40CH 25-200mW VTX
Frequency: 40CH
Current consumption: 300mA(type)
Antenna: Micro UXII Antenna
With Race band
Smartaudio ready
Weight: 3g
Caddx Baby Turtle Camera
TV system: NTSC/PAL changeable
Video Resolution: [email protected] / [email protected] / [email protected]
Power Input: DC 4.5-20V
Mini Illumination: 0.01lux
Image Resolution: 2 Megapixels
Working Current: [email protected]/[email protected] (low consumption)
OSD Menu: Yes (Support Voltage Display)
Video Files: MP4
Audio: Support
Electronic Shutter : PAL : 1/50-100,000 NTSC : 1/60-100,100
S/N Ratio: >60dB (AGC OFF)
Video Output: CVBS
3S 11.4V 450mAh 75C Lipo Battery
Capacity:450mAh
Voltage:11.4v
Continuous Discharge Rate: 75C
Weight: 42g
Connector: XT30
Features:
- Toothpick HD and Whoop HD 2 in 1 combo (Default Comes in Toothpick HD style)
- Toothpick style compatible both 2.5 inch or 3 inch propellers
- New design EX1203 High efficiency brushless motors
- Caddx baby Turtle provide 1080P 60FPS DVR video
- Full range receiver options
- Buzzer ready
- Smooth and powerful
- Compatible both for 2s-3s Lipo/LIHV
Package Included:
1x Larva X HD FPV Drone
2x 3S 11.1V 450mAh Lipo Battery
1x 5.8g Micro UXII Antenna
1x Propeller Disassemble Tool
Happymodel Larva-X HD whoop mode footage (7 min 1 sec)
Larva-X HD 2-3S toothpick HD Cinewhoop Whoopick (4 min 2 sec)
New Product Happymodel Larva X 100mm 2-3S Brushless FPV Racing Drone Rishi Micro Multirotor Drones 18 Jan 09, 2020 05:08 AM
