Feb 17, 2005, 10:29 PM
End to end soldering GP3300
What's the best way to make sure the "short" button on GP3300's make good contact with the adjacent cell?
Cut away shrink at flat end of cell? both ends of cell and use an insulator ring between cells?
Feb 18, 2005, 07:37 AM
Yep.
Take an X-acto knife, slide it under the insulation on bottom, then cut a ring of insulation off.
With practice, it's very easy.
Toshi
Feb 18, 2005, 03:31 PM
Thank you for the reply Toshi. Done many side by side; just starting end to end. Also, many thanks for your posts regarding Corona and of course EHBG!
Rob
Feb 19, 2005, 12:10 AM
Battery Junkie
wrenwright's Avatar
Check out Andy W's video on soldering end to end.
http://awilletts.ezonemag.com/makepack.mpg
Feb 19, 2005, 08:56 AM
It doesn't work that way
Nice Video! Thanks wrenwright.
Why does Andrew Willetts remove the shrink from all of the cells?
Would'nt it be better to just solder the cells then glue the sticks together and then shrink wrap the pack?
Also, where did he get that hammerhead tip? And what iron is that?
George
Feb 19, 2005, 09:16 AM
EDF Head
Haldor's Avatar
To improve cooling of the cells, vital for high amp applications - not neccesary for most sport apps.
Hammerhead tip can be had from www.aircraft-world.com
A Weller 40-80W iron will work.
Feb 19, 2005, 09:40 AM
Castle Tech
Joe Ford's Avatar
Actually Haldor I dont think they sell them anymore. I looked forever the other day to show a friend what one looks like. Its nowhere to be found. But you WILL need a hammerhead tip Pookee. I couldnt find the person who was selling custom made ones when I did a search and HL is out of them til March.
Feb 19, 2005, 10:30 AM
Battery Junkie
wrenwright's Avatar
Do an internet search for "hammerhead soldering tip"
I think Andy removes the factory shrink because the stuff will melt off the cells at very high discharge rates and short out the pack. The Kapton tape is good for several hundred degrees.
A Weller 40W is the one to get. Also, get some Dean's solder.
Feb 19, 2005, 04:50 PM
Registered Rebuilder
a hammerhead tip is listed at maxamps.com for 6.99
Feb 20, 2005, 09:14 AM
Build more, websurf less
FlyingW's Avatar
I've had this one for a few years and it works well:
http://members.cox.net/charliewhite/
Feb 20, 2005, 03:18 PM
Battery Junkie
wrenwright's Avatar
I bought one from Mr. White too and it works well. Just remeber not to leave it plugged when you're not actually soldering and use a natural wet sponge to clean it when in use. Also, you'll need to tin it before it gets all the way up to temperature.
Good luck.
Feb 20, 2005, 09:18 PM
Hammer Head Soldering Iron - FS
See: https://www.rcgroups.com/forums/show...50&postcount=1
RF
End-to-End soldering with GP3300? asm_ Batteries and Chargers 8 Aug 11, 2006 10:47 AM
End to end soldering GP3300's Mike Palko Batteries and Chargers 6 Dec 01, 2003 08:40 AM
Soldering Tip for end to end (Where to get) kenny_dilger Electric Plane Talk 10 Nov 29, 2001 03:47 PM
End to end soldering CP1300SCR's? GiantScale Electric Plane Talk 6 Sep 24, 2001 10:55 PM
Soldering Batteries End to End jdoan Electric Power Systems 10 Sep 15, 2001 11:08 AM
