Avios MiG-17 Fresco Jet Fighter 90mm EDF 1200mm
Avios has a new EDF Jet with this killer 90mm Mig-17. It comes packed with features like a 100A ESC with 5A BEC, split flaps, Oleo retracts and even airbrakes. We love the trim scheme on this one.
Hot Looking Mig-17
Avios has a new EDF Jet with this killer 90mm Mig-17. It comes packed with features like a 100A ESC with 5A BEC, split flaps, Oleo retracts and even airbrakes. We love the trim scheme on this one. Here's more on the Mig-17 from HobbyKing:
The Avios MiG-17 Fresco is a large 90mm EDF jet made of strong EPO foam with quality scale plastic details and a cockpit with a scale interior. It comes in an eye-catching arctic camouflage scheme that gives a huge presence in the air. This model is different from the rest and is a classic interceptor from the Vietnam War period.
The Russian Mikoyan-Gurevich MiG-17 (NATO reporting name "Fresco") entered service in 1952. It was a further development of the successful MiG-15 jet fighter from the Korean War era. It had large improvements made including a new, thinner and more swept wing and tailplane which allowed the aircraft to reach high subsonic speeds close to Mach 1 (the speed of sound) in level flight.
The MiG-17 was used during the Vietnam War to intercept bombers and fighter bombers rather than straight dogfighting with other fighters. The tactics used were effective against the slower, heavily loaded fighter bombers as they were maneuverable against these types of aircraft. The MiG-17 was replaced by the Mig-21 during the Vietnam War.
The Avios MIG-17 Fresco captures the looks, style and rakish lines of the full-size jet beautifully. The colour scheme Avios has used is similar to the civilian MIG-17's flown in the United States by the "Black Diamond" Display Team and they paint their aircraft in arctic camouflage. The MIG-17 is made of tough, high compression EPO and is supplied ready painted but you are required to apply the decals yourself. The MIG-17 boasts many features, it has a pre-installed 90mm 12 bladed fan unit with 3541/1550KV brushless outrunner motor, 100A ESC with 5A UBEC, 12 pre-installed metal geared digital servos, aluminium retract system, split flaps, air brakes and LED lighting. All you need to supply is a battery and 2.4GHz radio system.
The Avios MIG-17 Fresco is the same quality that you have come to expect from the Avios brand and is also very straightforward to build due to the low parts count. For a large aircraft, it can also be easily transported as the wings can easily be removed due to the quick wing connectors.
You will enjoy flying the Mig-17 as it has plenty of thrust for some exciting aerobatics and dogfighting. To ensure you come back to earth with ease it is fitted with split flaps and speed brakes for an easy landing.
Check out the Avios Mig-17 Here
Features:
  • Tough EPO foam construction with scale molded plastic details
  • Cockpit with scale details
  • Quick wing connectors
  • Pre-installed electronics
  • Wiring junction box
  • Ball-link controls for precision
  • Electronic retracts with full CNC aluminum landing gear
  • LED lighting system with landing lights
  • Working split flaps
  • Functional rear air-brakes
  • 12-blade EDF unit with realistic turbine-like sound
  • Easy to fit water slide decals
  • Easy assembly with bolt-together components
Specs:
  • Wingspan: 1200mm
  • Length: 1420mm
  • Flying Weight: 3250g
Includes:
  • Ducted Fan: 90mm EDF 12-blades
  • Motor: 3541-1550KV 6S Brushless outrunner
  • ESC: 100A Brushless with 5A UBEC
  • Servo: 12g x1 , 9g x11pcs
Requires:
  • 5000mAh 6S 45-75C Lipo Battery
  • 6~7CH Radio TX/RX System
Jul 30, 2019, 08:53 AM
www.gunnphotoservices.com
Matt Gunn's Avatar
I'd come out of hiding for this beauty!
Latest blog entry: www.gunnphotoservices.com
Jul 30, 2019, 03:15 PM
Shifteer's Avatar
I'm a sucker for a Mig! Not to be contrary but this screams for an ARF version without the retracts for a belly lander and likely far better performance without all that extra weight.
Jul 30, 2019, 05:02 PM
I bet for sure that without the landing gear, flaps and air rakes this would be a better flyer and belly lander. But what about hand launches? Even with everything removed i bet it would be still be quite challenging to hand toss a 6 lbs. plane.
Jul 30, 2019, 08:13 PM
flanker271's Avatar
Wish there is a grey version to allow us to custom our own paint scheme.
Jul 31, 2019, 07:17 AM
AA6JB
Bajora's Avatar
More chatter about this one than you probably are ready to read HERE
Latest blog entry: Updated FMS 1400mm J3 Cub
Jul 31, 2019, 11:27 AM
Larry Dudeck's Avatar
Jul 31, 2019, 03:16 PM
There is a non electronic arf version available. Get it while you can because once sold out there will be no more offered. That's according to HK.
Jul 31, 2019, 07:20 PM
4stripes's Avatar
https://hobbyking.com/en_us/avios-mi...f-arf-kit.html
I think it is worth spending 120 more for the full ARF version. Im not sure if the kit version comes with gear legs, but the ARF has the proper retracts to operate in the scale swept forward position (very cool). The EDF setup seems well suited to the model as well.
Jul 31, 2019, 10:47 PM
I agree, get the PnP it's the better deal. My understanding is that there are ZERO electronics included. Just bare airframe, foam only. At $250_275 it's not worth it. I have been tempted because of $$$ reasons but I'm saving for the PnP now.
Aug 02, 2019, 10:12 PM
that's gonna leave a scar
KCinNC's Avatar
came across this....the real deal
MiG-17 Fresco and F-86 Sabre Dogfight - Wings Over Waukegan Airshow 2014 (6 min 41 sec)
Aug 06, 2019, 02:34 PM
Well it has the typical Avios quality issues, it is still cool looking. Here is a video of a maiden with commentary on quality issues.
Avios MIG-17 90mm Jet Fighter (8 min 40 sec)
Aug 08, 2019, 07:00 PM
AA6JB
Bajora's Avatar
New Product Avios 90mm 1200mm MiG-17 Fresco The Snake Foamy EDFs 2648 Today 05:55 AM
Video Mig 17 90mm EDF jet Max speed and sound test robertmax Foamy EDFs 7 Jun 02, 2017 02:11 PM
Video Mig 17 90mm EDF jet Maiden flight robertmax Foamy EDFs 4 May 18, 2017 04:03 AM
Discussion FMS Mig-17 90mm EDF Jet T-CAT Foamy EDFs 18 Oct 19, 2016 10:46 AM
