Jul 31, 2019, 12:44 PM
Hi Guys,
The airfoil is one that I personally developed. I went through 10 different modifications before settling on the one that is included in the kit.
It is fully symmetrical and is thick enough to provide great all around handling both fast and slow. You all will be amazed at the extremely flat glide the GLH has power off, even with only 100 sq/in wing area.
Sincerely,
Doug (and Becky)
WillyNillies.com
Jul 31, 2019, 12:56 PM
Hi Guys,
All up weight covered with no electronics or power plants are coming in 2.8 to 3 oz.
All up weights finished and ready to fly are coming in from 6.3 to 6.8 ounces.
I personally select each piece of balsa and use what is best for the parts that are being cut. You will find I use medium to medium+ weight balsa. This grade is most easily available and most consistent. I purposely designed all our kits based on this consideration and to keep cost down. What we've ended up with is great flying planes that are not fragile and very easy to construct.
All fuselages and tail feathers are 3/32" and optimized for strength/weight with lightening holes.
All wing components (less center section sheeting) are 1/8". Again, fully optimized for strength/weight with lightening holes.
Further consideration was taken in that both fuselage sides were cut from the same sheet and nearly all wing components are cut from the same sheet. This keeps wing balance in check and part to part strength consistent from side to side etc..
Hope this helps answer most questions.
Sincerely,
Doug (and Becky)
WillyNillies.com
Jul 31, 2019, 01:43 PM
EB-66C Team Member
xplaneguy's Avatar
Thanks Doug!
Parts punched out, assembly begins!
Jul 31, 2019, 03:43 PM
EB-66C Team Member
xplaneguy's Avatar
Fuse assembly is done!
No instructions included in the kit, so I followed Doug's video (link below)….super easy! I added the glow engine/Cox .020 firewall and used epoxy to attach it.
NOTE: Instructions for all Willy Nillies' kits can be download:
https://willynillies.com/downloads
Quality of the wood and fit is outstanding. Thin CA used with capillary tube. By far, my fastest 1/4A fuse "kit" build! Great work, Doug!
On to the wing!
GLH 250 Fuse Build Video:
GLH 250 Fuselage Construction (23 min 41 sec)
Jul 31, 2019, 06:06 PM
Great job Tony! Are you having fun yet?
Sincerely,
Doug (and Becky)
WillyNillies.com
Jul 31, 2019, 07:50 PM
EB-66C Team Member
xplaneguy's Avatar
Thanks Doug!
I'm having too much fun! Enjoying this build very much!
Wing halves are finished. Time to join them!
Jul 31, 2019, 09:03 PM
EB-66C Team Member
xplaneguy's Avatar
She's starting to look like an airplane!
Currently working on filling and sanding all parts, then servo and fuel tank installation.
Jul 31, 2019, 09:05 PM
Nitro User
1/2A Nut's Avatar
So how much does the built up frame weigh?
Jul 31, 2019, 09:13 PM
Yay! $5 says it took you longer to punch parts out than it did to assemble everything? ��
Sincerely,
Doug (and Becky)
WillyNillies.com
Jul 31, 2019, 09:44 PM
EB-66C Team Member
xplaneguy's Avatar
Sincerely,
Doug (and Becky)
WillyNillies.com
How did you know?
Jul 31, 2019, 10:28 PM
Nitro User
1/2A Nut's Avatar
Doug how much does the GLH weigh assembled bare bones?
Jul 31, 2019, 10:37 PM
EB-66C Team Member
xplaneguy's Avatar
Wing servos installed.
Aug 01, 2019, 05:22 AM
1/2a nut,
I looked in my notes and. I cant find where I have ever weighed one assembed bare bones. I'll be sure to record that data this weekend.
Sincerely,
Doug (and Becky)
WillyNillies.com
Aug 01, 2019, 06:29 AM
Nitro User
1/2A Nut's Avatar
Thank you Doug much appreciated.
Aug 01, 2019, 09:14 AM
cannondale1974's Avatar
How fast are these? I built an original GLH 25 years ago with a TD .09 and it was (not slow).
Build Log Ace simple series ultimate (very detailed) Jonnybgood3 Balsa Builders 22 Aug 29, 2017 08:49 PM
Discussion Ace simple series corsair crashEMhard Electric Warbirds 11 May 07, 2017 09:01 PM
Discussion Pixhawk Simple and super Simple Modes help needed Paul80 Multirotor Drone Electronics 2 Aug 08, 2016 09:51 PM
Question HK Super Simple series 20a programming and arming Big_James Electric Plane Talk 7 Apr 26, 2014 08:13 PM
Discussion Because without Government, girls would be selling cupcakes all willy nilly like .... logan5 Life, The Universe, and Politics 151 Feb 02, 2014 06:15 PM
