This thread is privately moderated by ww5302, who may elect to delete unwanted replies.
Jul 29, 2019, 10:23 AM
Mia
FAQ
5 advantages of graphene Lipo batteries
Graphene Lipo battery becomes more and more popular. There are many well-known brands on the market, such as Hobby king, Dinogy, Lumenier and so on. This shows the popularity of graphene Lipo batteries. Our company also launched graphene Lipo battery as early as 2016 when we launched the DOGCOM brand.
http://www.tititop.com/a/chanpinzhon...6/0723/60.html
Our graphene Lipo battery offers the following advantages over normal Lipo battery:
(1) Higher Cycle Life Retention rate. In the cycle life test of 1C charging and 1C discharging, the capacity retention rate is more than 96% after 200 weeks.
(2) Higher discharge rate performance. Under the condition of high discharge rate, the discharge platform is still kept high. In the 65C power discharge test, the capacity retention rate can reach 90% of the 1C discharge capacity, and the discharge platform is higher than 3.45v.
(3) With the ability to charge quickly. In the 10C charging cycle test, the capacity retention rate was still over 90% after 100 cycles.
(4) The lower the temperature at which the current is discharged. Because of its high thermal conductivity, graphene batteries have a lower surface temperature when tested at high rates of discharge. In 10C, 20C, 30C, 40C, 50C, 60C, 70C room temperature (25 °C) discharge test, the highest temperature does not exceed 65 °C.
(5) Good safety performance. Graphene batteries can pass vibration, free fall, heat abuse, overcharge, and short circuit tests.
Our company specializes in wholesale graphene batteries for some years, if you want to seek battery suppliers, we will be the best partner. Please find our company advantages as follows:
(1) Many battery items are available. We can supply most of the battery models on the market.
(2) We have a lower requirement on MOQ: Our requirement on MOQ is 30 packs per item. Lower than most companies.
(3) Very short delivery time. If we have single cells in stock, we might be able to finish an order within 7 days. The longest delivery time is 25 days or so.
(4) Good quality. All of our batteries are strictly according to CE certifications (testing standard: EN62133-2:2017) regulations.
(5) Good sale-after. All bad battery packs will be replaced free of charge if the battery packs damaged under proper usage and storage within the quality duration 1 year.
If you want to learn more about graphene Lithium batteries, please contact me via email: [email protected]
Discussion Silicon Graphene HV LiPo Batteries (Si-Graphene) HyperionRocks Batteries and Chargers 49 Apr 03, 2019 07:44 PM
Question Lipo HV batteries - use as normal lipol advantages Emmet Brown Multirotor Drone Power Systems 3 Jan 31, 2019 03:59 AM
Discussion HK Graphene lipo battery ddekel Multirotor Drone Talk 0 Mar 06, 2016 02:27 PM
Advantages/Disadvantages of Battery Types (LiPo, Saphion, Nicad, etc) HAB Batteries and Chargers 8 Aug 31, 2005 03:02 PM
