Jul 28, 2019, 11:22 PM
I review RC Products
GBLynden's Avatar
ProFly OV-10 Bronco 1800mm ARF
This thread is for the new ProFly OV-10 Bronco 1800mm ARF.
Here is a flight video:
ProFly OV-10 Bronco 1800mm ARF RC Plane From Motion RC Second Flight (5 min 14 sec)
This is Motion RC's Unboxing video:
Unboxing - ProFly OV-10 Bronco 1800mm Balsa ARF - Motion RC (8 min 32 sec)
This is how Motion RC describes it:
The North American/Rockwell OV-10 Bronco was developed to meet the requirements of the United States Marine Corps Light Armed Reconnaissance Aircraft (LARA) program that was to provide the service with a multi-role aircraft that could operate in the armed reconnaissance and light attack roles from unprepared, forward airstrips. The ability to loiter in the combat area for an extended period was a key requirement.
The Bronco evolved to perform a broad range of roles including observation, forward air control, helicopter escort, armed reconnaissance, utility light air transport and limited ground attack. It has also performed aerial radiological reconnaissance, tactical air observation, artillery and naval gunfire spotting, airborne control of tactical air support operations and front-line, low-level aerial photography.
The ProFly OV-10 Bronco is scaled to approximately 1:6.7 and attention has been given to providing a realistic appearance with outstanding flight characteristics. The model was designed for electric power but can also be flown using a matched pair of internal combustion engines of about 6-7cc displacement.
Features:
  • High level of prefabrication right out of the box
  • Lightweight, strong, and fully sheeted laser cut balsa and plywood construction
  • Panel lines and details printed directly onto the pre-applied, high quality covering
  • Mylar C/A hinges on all control surfaces
  • Large easy access battery/servo access hatches with sprung loaded latches
  • Painted and detailed cockpit and interior included
  • Shock-absorbing suspension struts
  • Fiberglass control horns
  • Painted and details fiberglass cowls
  • comprehensive control and fitting accessories included
  • Two-piece, plug-in wings simplify transportation and assembly
  • Mounts for both electric and gas power options included
  • Fully illustrated instruction manual included and also available for download (see tab above)
Iincludes:
  • ProFly OV-10 Bronco 1800mm (70.8") Wingspan - ARF
Requires:
  • 6 Channel radio - select a minimum 6 channel radio from our Radio Collection
  • 6 Channel receiver - select a minimum 6 channel receiver from our Receiver Collection
  • 2x 35 - 42 size Brushless Outrunner Motors - we recommend the Admiral GP5 4220-770kV Brushless Motor
  • 2x 65 - 85 Amp Brushless ESC - we recommend ZTW Mantis 65 Amp Brushless ESC
  • 8x 45g standard servos - we recommend Hitec HS-485HB Deluxe Ball Bearing Karbonite Gear Standard Servo
  • Electronic 90 degree retracts (81 x 44 x 29mm) - we recommend Xwave RP400-90 Electronic Retract (Coming Soon)
  • 2x 4 Cell 14.8V 4000-5000 mAh LiPo Batteries with EC5 connector - we recommend TWO Admiral 4000mAh 4S 14.8V 40C LiPo Batteries with XT60 Connector
  • Electric propeller - we recommend TWO APC 12x8 Thin Electric Propellers
  • For 6 Cell 22.2V setup we recommend using TWO Tomcat G52 motors and TWO APC-E 12x8 propellers
  • 6 Cell compatible battery charger - select a minimum 6 cell (6S) charger from our Charger Collection
Jul 31, 2019, 07:34 PM
I can fix that!
doug.wagner's Avatar
You had me at OV-10!
Do you know if Seagull is the OEM for this line, and Tower's Phoenix?
Whatever the case, there is someone in Vietnam building some very fine models.
Jul 31, 2019, 07:43 PM
GBLynden's Avatar
That I don't know. I just captured footage of a buddy that built his and has to make a nice flight video with it. It flies so nicely that I decided to make a thread for it since no one else had yet lol
Aug 12, 2019, 12:51 AM
GBLynden's Avatar
This is Robert's third flight on his ProFly OV-10 Bronco.
ProFly OV-10 Bronco 1800mm ARF From Motion RC Third Flight (5 min 10 sec)
Oct 23, 2019, 07:12 PM
Electric Coolhunter
Thomas B's Avatar
Not much discussion on RCG about this great model......
Oct 23, 2019, 08:35 PM
GBLynden's Avatar
It is pretty new. Give it time
Oct 25, 2019, 06:54 AM
jobinseattle's Avatar
Looking at getting this for a winter project. Curious what people are using for hardware? I plan on using an electric setup.
Motors:
ESC's:
Props:
Retracs:
Servos:
Oct 25, 2019, 04:16 PM
JohnVHRC
JohnVH's Avatar
ProFly OV-10 Bronco Flight at Warbirds Over Whatcom
All gear used noted in my video description!
ProFly OV-10 Bronco 1800mm ARF From Motion RC at Warbirds Over Whatcom (4 min 11 sec)
Oct 25, 2019, 05:46 PM
GBLynden's Avatar
Motors:
ESC's:
Props:
Retracs:
Servos:
I have all of that noted in the description of my videos
Oct 25, 2019, 08:39 PM
GBLynden's Avatar
Check out this ProFly OV-10 Bronco Flight In Strong Winds! You'll see up close shots at the beginning, middle, and end.
ProFly OV-10 Bronco 1800mm ARF From Motion RC In Strong Wind (5 min 3 sec)
Oct 28, 2019, 05:42 PM
Sydney Australia
Hi Guys
Looks like a great model and I would enjoy building it
How far can you break it down for transport ?
Full marks to MotionRC for all the videos they help a lot
Oct 28, 2019, 08:12 PM
GBLynden's Avatar
They did a great job. As far as how it breaks down for transport, I don't know. The videos John and I took were of a buddy's plane
Oct 30, 2019, 07:57 AM
Hey Guys, Watch This.......
mike2663's Avatar
I'm putting one together. It's very well done. I used Motions recommended retracts. Power 46's for power on 4 or 5 cells.( not sure yet) Spektrum servos , CC esc's and picked up a couple of pilots from Benchmark.
Oct 30, 2019, 10:58 AM
Thx for sharing Mike, keep it coming....
Oct 30, 2019, 11:00 AM
Curious if anyone has used the recommended motors from Motion RC?
Discussion Profly OV-10 Bronco rosytime Electric Warbirds 1 May 21, 2019 05:06 PM
Discussion West Michigan Park Flyers OV-10 Bronco aircontrol Parkflyers 53 Jan 23, 2017 03:25 PM
Discussion Commom Sense prevails the OV-10 Bronco is Back. Sluf7 Life, The Universe, and Politics 5 Aug 01, 2016 12:10 AM
Build Log OV-10 Bronco nklkn Foamies (Scratchbuilt) 22 Jul 20, 2016 03:22 AM
New Product K&a ov-10 bronco Dinah Electric Warbirds 0 Dec 25, 2015 12:27 PM
