Jul 28, 2019, 10:18 PM
FrSky-MKT - Forum Sponsor
AndreaHuang's Avatar
New Product
FrSky New Arrival - Taranis X9D Plus & SE 2019
The FrSky Taranis X9D Plus 2019 is a re-designed version with additions like an additional momentary button placed on the top left shoulder making it ergonomically friendly for DLG pilots to activate launch mode, and features a program scroll wheel making it even easier to navigate the menus. The upgraded MCU is used in conjunction with a re-designed mainboard that further increases the computing capability and increases the data storage. The upgrades not only improve the running of LUA scripts, it also optimizes overall performance like voice speech outputs.
The 2019 version uses the latest ACCESS communication protocol, it boasts 24 channels with a faster baud rate and lower latency with a high-speed module digital interface. Along with the new spectrum analysis function added to the OpenTX firmware, it is now possible to check the airwaves for RF noise. This version will give you a further improved experience based on the classic Taranis remote control. Additionally, tons of extra upcoming features that ACCESS brings will make this an ideal transmitter for any skill level.
Name: X9DP 2019 - 3.jpg
Description: Name: X9DP 2019 - 4.jpg
Description: Name: X9DP 2019 - 5.jpg
Description:
The SE 2019 version is installed with the upgraded switches and M9 hall sensor gimbals and features the addition of a PARA wireless trainer function which makes them compatible with the FrSky Free Link App and AirLink S.
Name: X9DP SE 2019 - 1.jpg
Description: Name: X9DP 2019 SE - 2.jpg
Description:
SPECIFICATIONS
  • Dimension: 200*194*110mm (L*W*H)
  • Weight: 670g (without battery)
  • Operating system: OpenTX
  • Number of channels: 24 channels
  • Internal RF module: ISRM-S-X9
  • Operating voltage range: 6.5 – 8.4V
  • Operating current: [email protected]
  • Operating Temperature: -10℃ ~ 60℃ (14℉ ~ 140℉ )
  • Backlit LCD resolution: 212*64
  • Smart Port, Micro SD card slot and DSC Port
  • Mini USB interface: supports 2S Li-battery balancing charge
  • Model memories: 60 models (expandable by Micro SD card)
  • Compatibility: ACCST D16 and ACCESS receivers
FEATURES
  • Classic Taranis form factor design
  • Easy launch momentary button
  • Program navigation button
  • High-speed module digital interface
  • Installed with ACCESS protocol
  • Supports spectrum analyzer function
  • Supports SWR indicator warning
  • G9D potentiometer gimbal
  • Haptic vibration alerts and voice speech outputs
  • Supports wired training function
  • Supports PARA wireless training function (SE)
  • Compatible with FrSky Free Link App and AirLink S via mobile devices (SE)
  • M9 hall sensor gimbal and upgraded switches (SE)
TARANIS X9D PLUS 2019 1st RELEASE SPECIAL PRICE (TAX EXCLUDED): US$ 182
MORE DETAILS: https://www.frsky-rc.com/product/taranis-x9d-plus-2019/
TARANIS X9D PLUS SE 2019 1st RELEASE SPECIAL PRICE (TAX EXCLUDED): US$ 247
MORE DETAILS: https://www.frsky-rc.com/product/tar...-plus-se-2019/
Comparison List
Jul 28, 2019, 11:55 PM
mpjf01's Avatar
When will we be able to buy it please?
Will it be possible to customise orders? I would like a silver SE.
Are the M9 gymbals the same as those sold now for the X9D? Will I be able to use my relatively new M9R gymbals in the new radio?
Jul 29, 2019, 02:43 AM
Excellent news!
Now please continue (X9E 2019, ISRM module for X10 ..) ��
Jul 29, 2019, 03:03 AM
FJH
FJH
Hi Andrea,
Could you please clarify following questions:
1. Will an XJT RF module work in the JR module extension slot?
2. Can it be used simultaneously with internal RF module?
3. Can both internal and external RF module be operated in telemetry mode? Or must user decide for either the on or the other?
Jul 29, 2019, 03:46 AM
Bill Glover's Avatar
Nice to see that the SEs have standard switch labels etc. on them now, unlike the 'bare' shells of the previous version.
Latest blog entry: Eachine QX65 FPV quad review
Jul 29, 2019, 04:34 AM
Yes.
You may contact our dealers when they have replaceable accessories or customized products in stock.
And you can also use your M9/M9R gimbals on this new radio, no problem.
Jul 29, 2019, 04:50 AM
Originally Posted by FJH
Hi Andrea,
Hi FJH,
For your questions,
yes, it's similar to use the external module just like you did on original X9D Plus radio. And the good thing is, you can get the full speed signal transmission through the UART of this new radio connecting with the external module like R9M 2019.
Jul 29, 2019, 05:08 AM
FJH
FJH
Originally Posted by AndreaHuang
.... yes, it's similar to use the external module just like you did on original X9D Plus radio.
With the original "old" X9D (and X9E) we experienced each other interferences in simultaneous operation of internal and external XJT modules. That interferences were and are still the reason, not to use an external XJT simultaneously with the internal XJT in "old" X9D. This is the background for my questions #2 and #3 in my recent post. Maybe you review this condition with your technicans and then hopefully can clarify that detail.
Jul 29, 2019, 05:36 AM
Is it transmitter only or does it come with Battery, charger, case,...?
Is it possible to add a 6-pos switch like on the classic X9D(+)?
Jul 29, 2019, 08:39 AM
Sagitta Fanboy
The previous version came with the standard labels, just still on the sticker sheet.
Jul 29, 2019, 08:43 AM
Sagitta Fanboy
This looks great, the (few) UI warts of the classic are largely fixed and ACCESS is included.
I do have a few questions.
1. Does this mean that there will be no ACCESS upgrade for older X9D+'s?
2. On the 2019 model, is the S.Port line seperate between the external module and internal module (allowing both to deliver telemetry) or shared like the older design
3. Does the pushbutton switch use a standard switch hole? IE can it be moved to a better shoulder location
And why the heck are you still using Mini USB? It's a dead interface and its replacement is also dying. How about proper USB-C....
Jul 29, 2019, 09:13 AM
I know, but it would have been much easier to fit them before the switches & knobs were mounted on the Tx.
Jul 29, 2019, 10:03 AM
Regexistentialist
ridgerunr's Avatar
Please give this new Tx a new name
The names: "Taranis X9D, X9D+ and X9D+ SE" are already taken. Naming this new Tx the same as its predecessor will guarantee a LOT of confusion on these support threads! Although it looks and feels a lot like the X9D, this is an entirely new product that will undoubtedly have its own set of issues different from that of the original. Having the same name will cause a lot of questions where us support folks will be asking: "Which X9D are you talking about? The 2019 version is very different from the original".
Please give this new and significantly different transmitter a new and unique name!
Just sayin'
Jul 29, 2019, 12:07 PM
Just sayin'
Well, it looks completely the same so the same name with year tag seems understandable. It is also not that different in terms of anything else. A lot of problems are also with OpenTX etc.
Jul 29, 2019, 04:43 PM
mikeshellim's Avatar
The '2019' suffix will seem an odd choice in a couple of years.
New Product FrSky Taranis X9D Plus SE Special Edition Transmitter - An Upgraded Taranis D Gains Radios 209 Aug 14, 2019 07:39 AM
Discussion Frsky Taranis X9D Plus SE Radio Transmitter Special Version w/ Aluminum Alloy Stand & scousethief Banggood.com 0 Jun 07, 2018 07:13 AM
New Product FrSky Taranis X9D Plus SE with M9 Sensor Water Transfer Case--------Free Review BGjim Radios 316 Oct 16, 2017 03:44 PM
New Product Upgrade Taranis Loudspeaker for Frsky Q X7 / X9D / X9D Plus and X9DP SE sevet Radios 1 Sep 19, 2017 09:13 AM
