This thread is privately moderated by VicT, who may elect to delete unwanted replies.
Jul 27, 2019, 09:46 PM
Mini-HowTo
How to add drag to the Radian
The Radian has no drag devices but you can use the prop to add drag. Go into your DX6,7,8,9.....TX throttle curve menu and change the straight line points to a lower slope. Turn the curve to on and change point 2 to 5%, point 3 to 10% point 4 to 25%. You will not see a curve but adjust the points so that at half throttle the prop just starts to turn. In flight when you might not be able to see the prop turning move the throttle stick to the halfway point and you will be in the area where the prop just starts to turn. You will be providing windmilling thrust which is actually drag. Make sure to close the throttle just befor touchdown to avoid a prop strike.
Question How to add Banner adds to Rcgroups? Zipline Int Site Chat 2 Apr 08, 2019 07:43 PM
Discussion How much weight can Os Max 10 drag R4m Fuel Plane Talk 35 Apr 14, 2018 05:44 AM
Question How does sweepback affect induced drag? Stazzo Modeling Science 31 Mar 06, 2017 08:15 PM
Discussion how much drag really? squared JW fuse grfcon Dynamic Soaring 18 Mar 31, 2016 08:32 PM
Question How much drag does increasing wing cord add. turbo1889 The Builders Workshop 7 Aug 05, 2008 08:24 AM
