Sep 17, 2019, 02:16 PM
Originally Posted by rob.thomson
Has anyone managed to get this to work via VBI?
I have tried 3 different video receivers - and no joy.
Next step will be to bypass the inav osd - but I cant see why this should interfere.
Any thoughts?
Also you could try using a uart to pass MAVLink telemetry through the module
Sent from my SM-G930F using Tapatalk
Sep 17, 2019, 03:09 PM
Make sure the Telefly is connected after the inav osd. So the port that says video out on your flight controller goes to video in of Telefly and video out from Telefly goes to vtx.
Sep 18, 2019, 12:32 AM
RocketMouse's Avatar
Will telefly ever support mavlink?
Pitlab osd does.
Sep 18, 2019, 01:44 PM
Mini Obsessed
Shadrack's Avatar
Look what showed up today.
Ordered Monday. Here Wednesday. DHL is the best.
Now to figure out how to get Crossfire to it.
Also found out that the 2.4 Gattling only weighs 300 grams, not 800, so that will be going on this once I have it figured out.
Sep 18, 2019, 03:42 PM
Nice did you order directly from Myflydream or the AliExpress links? I ordered direct from MFD today so hopefully DHL is fast for me to and I at least have by next week.
Sep 18, 2019, 03:52 PM
openrc*****s *****
rob.thomson's Avatar
Thats exactly how I have mine
Sep 18, 2019, 06:02 PM
Selling my Mini Crossbow if anyones interested, its a couple of weeks old used it once at the field as new.....$110
PM if interested.
Sep 18, 2019, 11:46 PM
openrc*****s *****
Can't see why this is required.
GPS is being used to get the details.. Then rf. Link is vbi.
The docs clear tell you what wires to connect if using vbi and a shared gps.
To my understanding the Telefly can output a mavlink signal via the uart as an option
Sep 19, 2019, 01:52 AM
Never said it was required, I said it as an option to try.
Sep 19, 2019, 11:09 AM
openrc*****s *****
Ok. I am reaching the point I am going to right this bloody thing off!
My Arkbird tracker 'just works'.
I have now found that the telfly is seemingly badly affected by the camera in use.
At the moment I am thinking it is some kind on PAL/NTSC bug.
Essentially.. some camera work. Some dont!
Sep 19, 2019, 06:09 PM
Did you set the telefly to the same specs as the camera?
Sep 20, 2019, 01:25 AM
openrc*****s *****
I have tried swapping between ntsc and pal and no OSD.
No joy.
Tried this on both the camera and the Telefly and the fc
Even bypassed the fc. Same issue urgently only one of 6 cameras works!
Sep 23, 2019, 12:21 PM
Can you please tell the models of the unlucky and the lucky cameras?
Sep 25, 2019, 12:16 PM
What is send out of Tx2 L-Connector?
Sep 29, 2019, 06:13 AM
I got this rotary system - it turned out to be very interesting in work! Everything is simple to install - connected to the MFD autopilot everything works very accurately! Misters developers where to buy a cable for pair flights?
Discussion New Bluetooth module for MFD Crosshair AutoPilot support iOS and Android devices FPV_model FPV Equipment 4 Nov 11, 2019 12:01 PM
Discussion Looking for a new, light weight 3D indoor plane. DaN_Th3_MaN 3D Foamies 1 May 21, 2011 06:28 AM
Discussion New AP light weight mount cdi3d Aerial Photography 0 May 11, 2009 08:54 PM
New light weight wing decisions dustn Slope 54 Jul 29, 2005 10:45 AM
new light weight 3d plane from balsa products guyaneze 3D Flying 59 Jul 28, 2005 08:17 AM
