Sep 09, 2019, 08:28 AM
Thanks.
I like it so much I'm looking for a bigger, maybe 1/4 scale size for a gasser.
Sep 15, 2019, 08:01 AM
New pilot. She flys pretty well
Sep 30, 2019, 01:05 PM
Could you explain your painting procedure? I sprayed 3 coat of silver dope on Koverall and can still see through the airframe, where as your colors look really solid + GLOSSY !
Sep 30, 2019, 05:03 PM
is silver the final color?
I sprayed white first. It took about 5 light coats of white as the base, then the other colors only took 2 coats. After putting the vinyl lettering on I sprayed 2 coats of clear Butyrate.
Is it possible you are using too high pressure? Maybe spray a LITTLE wetter.
A trick I learned from full scale aircraft painting (dope) is to put your paint in the fridge overnight I believe it slows the drying a bit.
Sep 30, 2019, 05:40 PM
It was my first time spraying dope and yes silver is the final color. I was thinking of brushing the 4th coat on to see what happens. Sig Butyrate on the Smith mini plane.
Sep 30, 2019, 05:49 PM
Spray it. Little heavier, watch for runs. Little less pressure, try dope in the fridge.
What are you using to reduce/thin dope?
I have in the past wet sanded with 800 grit and painted.
Oct 01, 2019, 03:28 PM
I'm using Sigs thinner
Oct 01, 2019, 04:08 PM
by the way, are you spraying cross coats? one coat should be one horizontal on vertical.
so in reality its six coats.
Oct 02, 2019, 04:39 AM
Entropy is happening!
Jim.Thompson's Avatar
I would like one that size. I have a 25 cc Chinese two stroke on my list to convert to aero application. It might be a suitable size for a 1/4 scale Skybolt.
I suppose I would just build from a 3 view drawing, which seems to be my habit.
Unless, of course, there is a 1/4 scale plan around?
Jim.
Oct 02, 2019, 06:14 AM
Big Skybolt
http://www.hostetlersplans.com/Plans...t/skybolt.html
Oct 02, 2019, 05:31 PM
Thanks IC. That one would be good for a 50 cc twin. I know there is one on offer too, near me.
However, for my little 25 cc engine, a smaller scale would be suitable. That will take some judgement and careful assessment.
I am accustomed to building from a 3 view drawing.............that is not a problem for me.
Jim.
Oct 02, 2019, 05:37 PM
I'd like to see those plans.
Help! Sig Skybolt power choice propjok1944 Fuel Plane Talk 15 Sep 26, 2019 05:29 PM
Discussion Sig Skybolt Electrice Conversion Covering? ezrydr Painting and Finishing Tips 11 Feb 22, 2009 06:50 PM
Discussion Sig Skybolt ezrydr Glow to Electric Conversions 27 May 12, 2008 08:01 AM
Discussion Sig Skybolt 1-26 Flyer Fuel Plane Talk 5 Mar 03, 2007 11:22 PM
Alert Help Sig Skybolt instruction booklet wanted tgt The Builders Workshop 1 Nov 18, 2005 12:48 PM
