Jul 25, 2019, 12:47 PM
How do I construct motor mount with 5* dn and 3* side offset?
Can someone point me in the right direction to make a motor mount with
5* down and 3* right thrust. I am trying to do this in fusion 360 and my
brain is in a fog (as most times)? Offsetting one direction is OK, but trying
to get the second offset is very confusing. The easy way was draw lines on the block
and go at it with a belt sander. Any and all replies are welcomed and appreciated.
John
Jul 25, 2019, 01:31 PM
Duane, LSF IV
Wazmo's Avatar
I think you'll need to create a plane at an angle twice, once for each axis. Base the second plane on the first and add the second angle. Then sketch on the second plane.
QUICK TIP: Plane Creation (2 min 45 sec)
Alternatively, just draw your mount in orthogonal orientation and use joints to place it in the assembly at the desired angles.
Jul 25, 2019, 04:25 PM
Thanks Wazmo,
Got it by drawing (box) with 5* down thrust. Then using top, cut 3* from frame at 3*
angle. Then extruded parts I did not need. It is printing now. Thanks again,
John
Discussion How do I align the motor mount? mauiguy99 High Performance 5 Jun 26, 2018 11:51 PM
Discussion How do I build my first 5 gallons kerosene tank station with electric pump? superjet Fuel Jet Talk 12 Jan 21, 2017 02:36 AM
Discussion How do I mount the motor mount ? kuya- Electric Sailplanes 14 Jul 16, 2016 10:22 PM
Discussion How do I remove the glued on motor mount on my Slow Stick timewarpped Beginner Training Area (Aircraft-Electric) 5 May 21, 2016 07:38 PM
How do I set the 3-4* engine offset on SS rcpilot901 Aerial Photography 6 Aug 11, 2004 02:42 AM
