This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Jul 25, 2019, 12:18 AM
old4570's Avatar
MG 800 - Tentative steps
Measure twice , cut once ...
1) I glued in the horizontal stabs .. Since the fuse is two pieces , and the stabs are two pieces .. ( Go with the flow )
2) I used some double sided tape to put in the elevator servo . Then fitted up the controls for that side of the fuse .
2.5) I cut a small slot for the servo lead in the bottom of the servo slot .. ( There is none )
3) I will use some steel wire to join the two elevator sides ( Not included in the kit )
4) For the wing , I will try one servo , can always change my mind !
5) I used a circular servo arm cut to purpose and will allow for two connections ..
Next I will need to solder a 10A ESC ..
I want to dummy fit the motor and ESC before gluing the fuse ..
So far , a little bit of thinking ! Then some test fitting !
I want the ESC to be a clean neat install , leaving lots of internal space .. ( Dont want cabling everywhere )
Part 3
Maiden Flight
Discussion PRO DVR and Eachine 800 goggles need step up?? fin13 FPV Equipment 5 Nov 27, 2016 07:12 PM
Question Step-by-step PID tuning guide? (Luxfloat / Betaflight) xoxota Beginner Multirotor Drones 10 Jan 24, 2016 02:15 PM
Discussion Step-Up Gliders - Full House - Under $800 aeajr Sailplane Talk 25 May 10, 2013 03:38 PM
