Jul 23, 2019, 06:35 PM
psychedvike's Avatar
Question
Spectra control lines
I'm getting back into C/L after being out of the sport for a long time. I've heard about spectra and spiderwire being used for control lines instead of steel. I've heard the advantages of it being lighter, Less drag, minimal stretch, less prone to kinks, and being at least as strong as steel lines as long as the proper knot is used to terminate the lines. I'm building a 40 sized Electric stunt plane. I also might try a combat plane as well if I can find an opponent in the area to fly with. I found a thread on another site about it but the thread was from 2009. I think it should have been vetted out in ten years. So can anyone bring me up to date on the subject? Any opinions would be appreciated. What the up to date scoop?
Jul 23, 2019, 07:19 PM
The AMA site has rules for it's use. I think the 100 lb test is what is used for the .40 size. They still want the .018" dimension. There is a newer Quadra or Quatro or something that is just as strong but a fair bit thinner. If not competing you can just go a bit stronger than the pull test that you figure you will need, and check it often. The combat guys love it.
Discussion Line powered control line, for the minnimal space david.ingham Control Line 45 Jan 25, 2019 06:30 PM
Discussion Uncoated Dyneema or Spectra line? PGR Sailboats 16 Mar 22, 2018 07:36 AM
Discussion Spectra or Spiderwire lines? Kiwichris Control Line 6 Mar 15, 2018 05:06 AM
Discussion J. Roberts 3 Line Control Line Flight Control System badbill Control Line 0 Sep 27, 2013 11:31 AM
"Spectra line" hinge system. Anybody? mdlifcrisis 3D Flying 7 Jul 19, 2005 10:53 AM
