Aug 11, 2019, 07:44 PM
Rick T.'s Avatar
As Tom and Rubio would say, A Few More Crumbs today. Added and sanded the the left outboard tip today.. All that is left for left outboard is to sand the,leading edge. Once complete I will sand the left inboard to match and then join the two with extra support from two dihedral braces at the point where they are joined.
Aug 12, 2019, 03:25 PM
Rick T.'s Avatar
A little more today. The left side of the wing is complete except for more sanding. So far so good and yes there have been mistakes and screw ups. After sanding I will weigh that half of the wing.
Aug 13, 2019, 02:33 PM
Rick T.'s Avatar
Completed a little more this morning before work. I added the wing tip to the right side and sanded to shape then sanded the out board panel. Tomorrow after work I will sand the right inboard panel and hopefully join the two.
Aug 15, 2019, 09:55 PM
Rick T.'s Avatar
A few more crumbs today. The wing is 98% complete. All that is left is to sand and join the two with the dihedral brace specs.
Have not built a 2 meter in 25 years, god the wing is long. The 100 incher would have never fit in my car. Next up is to finish the fuse.
Now starting to think about covering combos: Blue Transparent with white fuse, Orange Transparent and blue fuse or Red Transparent and ???
Aug 15, 2019, 10:25 PM
VCscott's Avatar
Looking good!
My two meter stuff is a pain to stuff in my truck, they're to vulnerable to damage.
Two or three piece is much better.
Coming up with a good scheme and color that's not to complicated Is one of the hardest parts of building for me.
Aug 15, 2019, 10:34 PM
Rick T.'s Avatar
Thanks VC scott. It has been awhile. My last balsa build was a gentile lady whick I loved.
Aug 16, 2019, 09:32 PM
Rick T.'s Avatar
One half of the wing is sanded, will do the other tomorrow after work, then join and let sit overnight.
Also found out I am alergic to balsa dust. Been to the doctor twice, oh well almost done but from now will wear a mask.
Aug 16, 2019, 11:24 PM
VCscott's Avatar
Oh no, that’s a bummer!
Definitely wear a dust mask. I do some times but it’s easy to forget.
Would taking something like Claritin help?
Aug 16, 2019, 11:58 PM
Rick T.'s Avatar
VC
Have plenty of antibotics, but the mask is a must.
Aug 17, 2019, 10:18 PM
Rick T.'s Avatar
It is a WING. Joined the two haves tonight and all that is left is more sanding and balancing. Do not know if I built it heavy or not but the wing came in at 7 ounces.
Aug 18, 2019, 02:00 PM
It's not going to build itself
TRISME's Avatar
Sounds light for how big of a wing it is. Great job!
Aug 18, 2019, 02:20 PM
Rick T.'s Avatar
Thanks Tom. It did come with a lot of screw ups. I am hoping for around 30 to 33 ozs. Next up today, The Fuse.
Aug 18, 2019, 10:05 PM
Rick T.'s Avatar
A few more crumbs. Today I placed servos exactly where the plans called for. Once completed I meaured and installed the sleeve for the torque rods and shaved off the ends so they are level with the sides of the fuse. Then installed hatch and node block. For the hatch I will secure with magnets. Tomorrow I will shape the nose and sand the hatch flush. Enough for today.
Aug 18, 2019, 10:21 PM
TRISME's Avatar
Way to keep it going Rick!!
Aug 18, 2019, 10:27 PM
Rick T.'s Avatar
Thanks Tom.. Any input is always appreciated
Discussion Build-Log carbon composite 2 meter fast FPV plane (200+MPH) KondorFPV FPV Aircraft 19 Jun 17, 2019 06:45 AM
Question Two Meter Sig Riser Glider (Electric Conversion) RonT Electric Sailplanes 3 Nov 14, 2018 01:42 PM
Discussion Sig Riser 2 meter dankar04 Thermal 360 Oct 05, 2016 01:02 PM
Build Log Sig Riser 2M - build as electric with 2-piece wing Aussie Jack Electric Sailplanes 93 Jan 10, 2014 02:02 AM
