Jul 29, 2019, 08:52 PM
It's not going to build itself
TRISME's Avatar
Alright Rick!
Jul 29, 2019, 09:12 PM
Rick T.'s Avatar
Thanks Tom..... Working on PSS planes are soooooo much easier but I am learning with balsa again.
Jul 30, 2019, 07:42 PM
Rick T.'s Avatar
Today I completed a little bit more of all 4 wing panels. They are not finished because I have a little bit more to do, then sanding. Now at least I can start on the fuse Thursday at our build night.
Aug 02, 2019, 10:40 AM
Rick T.'s Avatar
More work completed at build night. Added doublers ti the fuse along with triangle balsa to the top of the fuse. Before fuse goes together I will strengthen places that take a beating on hard landings. Easy to strenghten now rather then later after a break.
Aug 02, 2019, 10:55 AM
Steve Neill
BK 1125's Avatar
This builds pretty quick for wood and it's a great solid flyer. When all the PSS are down because the lift it you'll be flying still on 3-4 mph no problem plus thermal hunting is fun too when you bungee the plane in a open field. You doing great!
Aug 02, 2019, 12:41 PM
Rick T.'s Avatar
Thank you, more building today
Aug 02, 2019, 01:46 PM
VCscott's Avatar
You're moving right along! You’ll will be floaty flying very soon.
Aug 02, 2019, 01:50 PM
Rick T.'s Avatar
Aug 02, 2019, 05:53 PM
Dale G......OZD
he4gott's Avatar
I love my old Oly 650!
Aug 02, 2019, 06:58 PM
Rick T.'s Avatar
Well it had to happen. Went to instal the formers but they seem to be wrong according to the plans.
Any opinions ?
Aug 02, 2019, 10:38 PM
VCscott's Avatar
Time for the Dremel.
Aug 02, 2019, 10:46 PM
Rick T.'s Avatar
Just talked with Tom, will trace and dremel them out. Thanks for the idea guys, your input is much appreciated.
Aug 03, 2019, 08:00 AM
Old Master, New Grasshopper
toro's Avatar
Drill each of the 4 corners of each cutout to get a nice round finished edge without having to Dremel it round
Latest blog entry: Pics
Aug 03, 2019, 11:01 AM
Rick T.'s Avatar
Jeremy
I screwed up, either I lost them or they are trashed, so I have two options. I can call Sig on Monday and they will send out a set of 3 ( formers 1, 2 and 3 or I think I have some 1/8 in lite ply to cut new ones. I will take the 3 that I have and trace the out, then add 1/4 inch all the way around so they match the plans. Right now I have a major head cold and I am working at the golf course because they could not get someone to cover. So I will probably work on the fuse Tuesday.
Aug 03, 2019, 11:37 AM
toro's Avatar
ah ha ! I see what happened. You kept the punch outs, and the actual formers got lost. Yea, cut some new ones. Easier.
Discussion Build-Log carbon composite 2 meter fast FPV plane (200+MPH) KondorFPV FPV Aircraft 19 Jun 17, 2019 06:45 AM
Question Two Meter Sig Riser Glider (Electric Conversion) RonT Electric Sailplanes 3 Nov 14, 2018 01:42 PM
Discussion Sig Riser 2 meter dankar04 Thermal 360 Oct 05, 2016 01:02 PM
Build Log Sig Riser 2M - build as electric with 2-piece wing Aussie Jack Electric Sailplanes 93 Jan 10, 2014 02:02 AM
