This thread is privately moderated by Qwinout, who may elect to delete unwanted replies.
Jul 22, 2019, 10:59 PM
New Product
Happymodel XT30 Plug Pigtail Power Wire 100F Capacitor for Mobula7 HD Sailfly-X TRASH
Happymodel XT30 Plug Pigtail Power Wire 100F Capacitor for Mobula7 HD Sailfly-X TRASHCAN UR85 UR85HD Crazybee F3 / F4 PRO Parts
https://qwinout.com/products/1pcs-2p...6316c0b5&_ss=r
Wholesale link
https://qwinout.com/products/wholesa...6316c0b5&_ss=r
Wire length: 70mm(include xt30)
Height: 2.6gram
Used for : Crazybee F3 / F4 PRO series flight controller
Can avoid the risk of burning the mosfet or the 5v regulator at the moment of power on
With this Capacitor , we can use 3S 300~350mah battery for the Crazybee F4 PRO V2.0 and Crazybee F4 PRO V2.1 , and 2s 300~350mah battery for the Crazybee F4 PRO V1.0
And if you want to use the battery above 350mah , we recommend use 220 uF or above capacitor.
We found most of the 5v regulator and esc of the Crazybee F4 flight controller burnt after mod the PH2.0 to XT30 . Also, more powerful the battery is(lower esr than stock battery) , more possibility to fail. And, the temporary solution is add a low esr capacitor onto xt30 connector. This capacitor should have a esr less than 0.2 ohm and have a capacitance more than 100uF. Rubycon ZLG/ZLH series and Samyoung NXB series are what we have tested and recommended.
Following pictures show what happened after plug in battery:
Without 100uF, the max spike voltage increase to ~25v while with 100uF it decrease to about 20v, which is acceptable to Crazybee F4 PRO V2.0 and Crazybee F4 PRO V2.1
New Product Sailfly-X HappyModel (ToothPick version) MultirotorDrones Micro Multirotor Drones 1390 Sep 23, 2019 02:36 PM
