Nov 29, 2019, 06:15 PM
Originally Posted by Sam Harbold
I am using a Turnigy 5000 5S 25C battery. I have attached a pdf with the equipment I used.
Did you reverse the motor shaft?
Nov 29, 2019, 08:13 PM
Sam Harbold's Avatar
No I used the bolt on prop adapter that was supplied with the motor. The shaft of the motor sticks back through the motor mount as you can see in the attached photo.
Dec 27, 2019, 02:08 PM
TheRocksKid's Avatar
Just curious what plastic (ABS, PLA, etc) you used for the 3D prints?
Dec 28, 2019, 08:36 AM
Filiment: Inland PLA+
Printer: Anet A8 with glass on heat bed
Bed Temp: 65 C
Hot End Temp: 212 C
Print Speed: 65 mm Sec.
Resolution: .2mm
Infill: 20%
Last edited by Sam Harbold; Dec 29, 2019 at 08:44 AM. Reason: added infill and resolution settings
Help! Tower Trainer 40 Supersam Beginner Training Area (Fuel) 18 Jun 02, 2016 04:20 PM
Discussion Hobbico 60 Mk III - Tower Hobbies Trainer 60 or Tower Hobbies trainer 40 Charlescd Beginner Training Area (Fuel) 10 May 07, 2016 12:20 PM
Discussion Tower Kaos 40 electric conversion Wrenchbody Electric Plane Talk 28 May 02, 2016 05:38 PM
Discussion Not sure what I need Tower 40 Trainer H2daB Glow to Electric Conversions 36 Apr 04, 2016 12:56 PM
Discussion Tower Trainer 40 to Electric - Prop Size Issue highamperage Power Systems 7 Jun 26, 2011 04:36 PM
