This thread is privately moderated by Qwinout, who may elect to delete unwanted replies.
Jul 19, 2019, 03:04 AM
New Product
GEPRC Phoenix3 GEP-PX3 140mm Wheelbase F4 FC 3 Inch FPV Racing Drone
GEPRC Phoenix3 GEP-PX3 140mm Wheelbase F4 FC 3 Inch FPV Racing Drone PNP BNF W/ RunCam Micro Swift Camera VTX 1206 4500KV Motor
https://qwinout.com/collections/fpv-...6-4500kv-motor
Specifications:
Name: PHANTOMThe size of the gep-px3 version is more of an outdoor flight, and the size and power upgrades mean better flight performance.
The frame is a 3-inch version of PX, and the lens protection material is still 7075 aluminum.The overall use of 3K carbon fiber, 3mm thickness of the bottom plate and 1.5mm thickness of the top plate to ensure the durability of the frame.3D printed TPU tail combination LED lamp design.Position the battery up and down according to the flight habits.The overall model is compact and delicate, beautiful appearance.
This major upgrade to the powerpack will be paired with SpeedX's gr1206-4500kv motor and the EMAX AVAN Mini 3-inch propeller, powered by a 4s battery, for excellent flight performance.
The camera adopts Runcam Micro Swift, and the flight control system adopts STABLE F4 Towe 20A version, which is simple and convenient to install, STABLE and good system, suitable for small wheelbase competition.
Specifications:
Frame: GEPRC GEP-PX3
Wheelbase: 140mm
Camera protection: 7075 aluminum
Bottom plate: 3mm
Top plate: 2mm
side plate: 1mm
Motor: GEPRC GEP-GR1206 4500Kv
Propeller: EMAX AVAN Mini propeller
GPRC STABLE F4 Tower (GEP-F4-BS20A-VTX58200-M) V1.4
Flight Controller: Betaflight F4 OMNIBUS
ESCs: 20A BLHeli_S/Dshot150/300/600
VTX:GEP-VTX58200 48CH Mini FPV Transmitter(OFF/25/100/200mW)
Camera: RunCam Micro Swift 1/3" 600TVL FPV camera 2.1mm lens CCD
Receiver: Frsky XM Plus (ONLY BNF INCLUDE)
Weight: 104.2g (without battery)
Flight time: 4 minutes
You might need the following equipment to fly
Remote control: You can choose: Frsky X9d or something like that
Goggle: Such as FatShak V2 or something like that
Battery: The novice recommends using the 2s 450-600mah battery. Professional flying professionals
recommend 3s 450mah-550mah
Features:
The GEPRC flying team carefully calibrations PID, the factory to the binding receiver can fly.
Using the mature GEP-PX3 frame, and the base plate to 3mm thickness, all 3K carbon fiber main board, strong resistance to fall.
Using the GR1206 4500kv motor andEMAX AVAN Mini blade propeller and 4s 450mAh battery, perfect match, efficient and violent.
Using STABLE F4 Tower, easy install, stable
Using Runcam micro swift camera, make sure clarity
Tested the best speed 120km/h+
Include:
1x Phoenix Mini Race Quad,Fully assembled and flight-tested
2xEMAX AVAN Mini Propeller
2x 10*150mm Battery Strap
1x XT30
2x Battery silicone pad
1x Frsky XM PLUS Receiver(ONLY BNF)
New Product Geprc GEP-CX Cygnet 145mm 3 Inch RC FPV Racing Drone Stable F4 20A 48CH RunCam Split scousethief Banggood.com 328 Aug 13, 2019 07:43 AM
New Product Geprc Phoenix3 PX3 140mm Stable F4 3 Inch FPV Racing Drone PNP BNF w/ RunCam Micro Sw Merch Banggood.com 5 May 05, 2019 09:41 AM
New Product GEPRC GEP-Crocodil GEP-LC7-1080P 315mm 7 Inch RC FPV Racing Drone Betaflight F4 50A alex_nikiforov Banggood.com 4 Apr 03, 2019 04:24 AM
New Product Geprc GEP-CX Cygnet 115mm 2 Inch RC FPV Racing Drone Stable F4 20A 48CH RunCam Split scousethief Banggood.com 1 Mar 22, 2019 09:33 PM
