Jul 18, 2019, 09:06 AM
Spetnaut's Avatar
Build Log
Did I fry my build?
Building my first Quad, it’s a Tyro109 kit, Matek405 FC. So I completed the build process, hooked up power with a smoke tester and everything went good. Did it’s boot up sequence of beeps, motors moved a tiny bit, so I thought all was fine. I could not see any shorts or bridged connections either.
Plugged in raw power from the Lipo and and the FC did not go through it’s entire boot sequence maybe half way then just started beeping and a fast flashing red light. Does the same now with the smoke tester also. I can still hook up to beta flight. I can see Lipo voltage in the power tab. But something is not rite the way it boots up and beeps / flashes non stop.
What is going on? Hopefully someone can help.
Edit: FIXED!
Jul 18, 2019, 10:30 AM
Did you check main battery plug's electrical resistance on the quad with a multimeter for short circuits?
Jul 18, 2019, 10:55 AM
Spetnaut's Avatar
Did I fry my build?
In short, no. But that is what the smoke tester is for?
Iíll check with a volt meter later, but I do not think this is the case.
Sent from my iPhone using Tapatalk
Jul 18, 2019, 12:14 PM
Spetnaut's Avatar
Did I fry my build?
So I tried giving it full Lipo power again without the smoke tester. I am able to connect to the FC in betaflight and spin up all 4 motors. But it continues to beep like crazy and blinking red on the FC.
Discussion EMAX Babyhawk Newbie - Did I fry my FC? meDented Multirotor Drone Electronics 2 Mar 14, 2018 09:48 AM
Discussion Did I fry my taranis x9d backboard? Redtail2426 Radios 8 Feb 14, 2018 04:31 AM
Help! Did I fry my vTx NoLimitRC FPV Equipment 5 May 31, 2017 06:52 AM
Help! Did i fry my Naze32?! gregory21greg Multirotor Drone Talk 1 Jul 17, 2016 05:50 AM
Help! Did I just fry my whole build? bombarie Multirotor Drone Talk 24 May 02, 2016 02:43 AM
