Jul 16, 2019, 11:36 PM
New to pusher jets
Any tips or resources for converting edfs to pushers?
Jul 21, 2019, 07:55 AM
Most of the small pusher jets Iíve built are roughly the same size as 70mm EDFs.
Iíve been running 3200kv motor on 3s 2200ís using a 6x6 speed prop in the 400 watt range.
Depending on the edf, you may have to remove foam out of the front of the plane so that you can move the battery forward to get the proper CoG.
Jul 24, 2019, 09:44 PM
Appreciate the tip.
Aug 03, 2019, 08:24 PM
What is your motor and esc of choice?
Discussion NEW!! Taft-Hobby SU-27 Camo Pusher Jet PNP Version Mike_eee Pusher Prop Jet Models 15 Jun 16, 2019 09:31 PM
Discussion i have a pusher jet f16 fiberglass fuse sherlockshah Power Systems 3 Mar 30, 2019 02:22 PM
Discussion Trying something new - Micro jets for EDF or pusher zbrubaker Micro EDF Jets and Power Systems 71 May 08, 2018 07:27 AM
Discussion taft viper jet pusher prop arnauddecotter FPV Aircraft 294 Jul 13, 2017 06:04 AM
Question GWS jets adapted to pusher prop? zen4013 Foamies (Kits) 5 Dec 30, 2015 09:09 PM
