Jul 16, 2019, 07:35 PM
Help!
G-RX8 with FrSky Battery Voltage Sensor (FBVS-01)
How do I setup the FrSky Battery Voltage Sensor (FBVS-01) with the G-RX8 receiver in Opentx?
I've used the multi-cell sensor just fine but can't seem to get this one going. I did find a Youtube video that said to only use the red wire to keep from having a ground loop on a different receiver. Is that good advice.?
Jul 16, 2019, 09:12 PM
Sagitta Fanboy
The FBVS-01 isn't a sensor per se, it's a voltage divider. So it works differently from a real S.Port sensor.
It needs to be plugged into the Ain port on the G-RX8's S.Port header, you shouldn't need a ground wire unless you have a fully isolated BEC/ESC (which is unlikely)
Jul 17, 2019, 01:33 PM
Alt+24=↑ Alt+25=↓ Use num keys
Miami Mike's Avatar
Originally Posted by mawz
... you shouldn't need a ground wire unless you have a fully isolated BEC/ESC (which is unlikely)
And if it doesn't work with just the red wire connected because you have a fully isolated BEC/ESC (which is unlikely) then you'll need to figure out why it's set up that way, but don't just add a ground wire because if you do that then you'll no longer have a fully isolated BEC/ESC.
Dec 11, 2019, 03:01 PM
Thanks so much for the reply. I read it a shortly after you posted, but forgot to thank you.
Dec 22, 2019, 09:33 PM
Sailplane Mafia
gquiring's Avatar
I made a video on the G-RX8 receiver for setup. If you skip to 7:09 it will help explain the voltage sensor hookup.
FRSky G-RX8 receiver bind setup howto (11 min 25 sec)
Dec 22, 2019, 10:38 PM
Thank You
Thank you for the useful information. I'll try that hookup as soon as the holidays slow down.
Merry Christmas and Happy New Year!
Discussion D4r-ii + vario. Can I add FBVS-01 voltage sensor too? ratbird911 FrSky 1 Apr 25, 2017 05:12 PM
Discussion Frsky FBVS-01 Voltage Sensor for beginner sooner2k1 Multirotor Drone Electronics 2 Mar 03, 2015 07:06 PM
Discussion FRSKY FBVS-01 voltage question Charlie6017 Multirotor Drone Electronics 6 Nov 24, 2014 11:35 AM
Question Will this "FrSky Lipo Voltage Sensor FLVS-01" work with the TARANIS CyberCrash Radios 3 Nov 01, 2014 05:02 PM
Discussion FBVS-01 Frsky Sensor Help Charlie6017 Multirotor Drone Electronics 0 Apr 26, 2013 08:28 PM
