Jul 15, 2019, 07:33 PM
The Junk Man
Lightest 3 axis Stabilizer NOT Horizon Hobby models
Looking for the lightest 3-axis stabilization system not by Horizon.
Any info appreciated.
Tom
Jul 16, 2019, 11:10 AM
EvanM's Avatar
I would look to the small flight controllers usually found in quadcopters. They can be configured for fixed wing through the betaflight (cleanflight, inav, etc) control panel. I recommend that you get at least the F4 or F7 versions.
https://www.readymaderc.com/products...-rxsr-receiver
I have also de-cased the S6R receivers to save size and weight.
Jul 16, 2019, 11:17 AM
EvanM's Avatar
Or, the Volantex v761-1 Mini Trainstar has a gyro.
Jul 16, 2019, 11:40 AM
We are not men, we are DEVO 7e
xanuser's Avatar
you can get 16mm FC boards that weigh 2.5g or less. course they are usually for lower cell counts, so might need a voltage regulator.
for fixed wing i don't see the real need for f4 and above, but it cant hurt, and makes firmware upgrading easier. -but in reality you don't really need to upgrade and it will fly just fine with stock firmware and proper settings. just depends on what OP really wants out of it.
Jul 16, 2019, 03:16 PM
The Junk Man
Thanks for the suggestions. I should have said I was primarily looking for an all-in-one solution similar to the Lemon stabilizer models but maybe a bit lighter.
Tom
Jul 16, 2019, 03:48 PM
EvanM's Avatar
Brushed? Brushless? Volantex maybe your best bet for an AIO on the brushed side (buy the plane and scrap it for parts). If you find a brushless solution, be sure to post it her for the rest of us.
Jul 16, 2019, 04:18 PM
The Junk Man
Brushless.
Tom
Jul 16, 2019, 05:12 PM
EvanM's Avatar
Looks like maybe everything but servos are integrated...
https://www.rcgroups.com/forums/show...-w-6-Axis-Gyro
Help! Lightest 2 Axis Gimbal For Bugs 3 Pro hellothere1993 Aerial Photography 12 Sep 19, 2018 06:17 PM
Discussion 3 axis gyro stabilizer is not working mian558 Electric Plane Talk 0 Jul 12, 2018 05:10 AM
Question 3 axis vs axis stabilization Thickfog Mini Multirotor Drones 6 Apr 25, 2017 01:00 PM
