Jul 14, 2019, 01:31 PM
Question for Hobbywing Seaking 30A
Hi,
I am changing motors, ESC, RC in my stock bait boat with Deeper wifi sonar.
Now I have the Hobbywing ESC which should have a BEC for the receiver.
But I can't see any extra wires ? Where do I get the 6v from ?
http://www.lxrcmodel.com/details.asp...=4256&classId=
Jul 15, 2019, 04:08 AM
If the ESC has an internal BEC to derive its control voltage from the main battery, it will also appear on the plug that you use to connect to the radio. As long as electricity only has to travel one way along the wire at any one time, it doesn't care which way that is. An ESC with a built in BEC will supply the receiver, one without will get its control supply via the radio from whatever the supply is. Discrete radio battery, other ESC, stand-alone BEC unit, whatever.
Anything requiring 6 volts can get it from the radio, just plug it into a spare channel, or create a spare channel for power using a Y lead.
Jul 15, 2019, 07:34 AM
Discussion HobbyKing 30A BlueSeries vs Hobbywing Platinum 30A for F450 Naza mauribilis Multirotor Drone Talk 0 Jun 21, 2018 03:43 AM
Discussion Hobbywing Seaking 180A V2 vs. V3 Glondar Racing Boats - Electric 1 Mar 20, 2016 04:04 PM
Discussion Can the HobbyWing PlatinumPro 30A Opto ESC be used for Std Aircraft? makeitworst Power Systems 1 Dec 30, 2015 07:13 AM
Discussion HobbyWing Seaking 180 and Turnigy 180 ESC's Yort69 Racing Boats - Electric 1 Sep 03, 2013 01:25 PM
Question Hobbywing Seaking 2848sl 3900KV rmartin00 Racing Boats - Electric 15 Mar 24, 2012 05:24 AM
